Problem with SpellForce 2
  • Problem with SpellForce 2
    I downloaded and installed SpellForce 2. When the game starts loading, I get the following error message "An access violation occured and the program must quit".
    =[ ProtectionID v5.1e ]=- (c) CdKiller & [x/xxx]
    Build 17-08-2006....
    > Ready
    Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\protect.dll
    File Type : Dll, Size : 318956 (04DDECh) Bytes
    [!] Starforce v3.7.13.00 (Build 28.02.06) detected !
    [!] [PROTECTiON LEVEL] -> Starforce Professional
    [!] [PROTECTiON iNFO] -> data protection and StarForce virtual file system enabled
    [!] [PROTECTiON iNFO] -> cd/dvd check enabled, identification of emulators is on
    [!] Possible CD/DVD-Key or Serial Check -> SerialNumber
    - Scan Took : 0.922 Seconds
    Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\protect.exe
    File Type : Exe, Size : 14167864 (0D82F38h) Bytes
    -> File has 13813808 (0D2C830h) bytes of appended data starting at offset 056708h
    [!] Starforce Protect.exe v3.6.10.06 - 3.7.19.01
    - Scan Took : 3.203 Seconds
    Scanning -> C:\Program Files\SpellForce\SpellForce 2 - Shadow Wars\spellforce2.exe
    File Type : Exe, Size : 8211968 (07D4E00h) Bytes
    [!] Starforce wrapped !
    - Scan Took : 2.750 Seconds
    They blacklist alot of emulators ive tired alot of starforce anti things but still nothing Sad
    http://m0001.gamecopyworld.com/games...%202%20v1.0%20[MULTI5]%20No-CD/Fixed%20Image
    Note: This Fixed Image does only work for version 1.0, it will not work anymore after upgrading to a newer version (which installs a new StarForce v3.7.16)!
    if anyone has the link to or files for spellforce 1.00 please email me or something with them
