After reboot -> invalid device
  • #31
    OK, I will be pleased to help you !
    bye
    Vince
    • #32
      Check your email please.
      • #33
        same thing for U
        bye
        • #34
          I just wanted to say that the problem went away on my PC with Daemon Tools Version 3.41. However, I do not really know if the problem went away because I installed the new version. I also went to Windows Update and loaded new security patches there.
          However, Thanx for the support
          • #35
            I'm lost
            I totally lost here..
            I have uninstalled DT 3.41 and tryed to installed a older version 3.31..
            That seems to work, undtil I restartet the computer..
            Then the error pop ups again..
            I have also tryed to installed Alcohol 120%, but the program gave me a error every time, the computer was restartet...
            This is the error, that I got, after restartet with DT 3.31 installed.
            0000: 00 00 00 00 01 00 5a 00 ......Z.
            0008: 00 00 00 00 04 00 04 c0 .......А
            0010: 80 c6 b0 f8 c0 00 00 c0 €Ж°шА..А
            0018: 00 00 00 00 00 00 00 00 ........
            0020: 00 00 00 00 00 00 00 00 ........
            The new problem that I gets, is that I get a error under Device Manager..
            " PnP Bios Extension " -- Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.
            What the devil is that? I have never had this problem before.. Is it relatet with Deamon Tool??
            I hope that I soon will be able to again use DT without any problems :-)
            • #36
              VeNoM386 : I have send you back my email
              Vince
              • #37
                Same Problem
                Operating System: Windows XP Home Edition
                Burning Software: Nero 5
                Anti-virus Software: no
                DAEMON Tools Version: 3.41
                I have the same problem!
                what can i do against it?
                Can you send me this driver please (which reports errors a little bit better)?
                I have the same problem with Alcohol 120 %!
                please help me to fix that!
                • #38
                  Those who have such problem with 3.41 can mail me for temporary fix
                  • #39
                    please mail me the tempory fix!
                    amirhadi@t-online.de
                    thanx!
                    • #40
                      Venom i didnt get any mail yet?
                      • #41
                        Wasn't it you who mailed me it worked fine after i sent him fix?;-)
                        There were already bunch of guys....
                        Mail me and explicitly say who you are.
                        • #42
                          Win2K will not boot after restart
                          Operating System: Windows 2000 SP 4, recent security patches
                          Burning Software: Nero 5.5.9.13
                          Anti-virus Software: NAV 10.0
                          My Win2K machine will not fully boot up after installing DT 3.41. It hangs right after the keyboard flashes during the Win2k Splash screen. If I disable the ST3SHARK SCSI in safe mode, it will then boot up fine. It does keep trying to install a new controller while disabled although. I removed DT 3.41 and reinstalled 3.29, and that version still work fine without a problem. I rebooted several times to make sure it worked after reboots also.
                          Here are some system event errors when 3.41 was installed
                          Event Type: Error
                          Event Source: st3shark
                          Event Category: None
                          Event ID: 4
                          Date: 10/18/2003
                          Time: 11:59:33 PM
                          User: N/A
                          Computer:
                          Description:
                          The description for Event ID ( 4 ) in Source ( st3shark ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. The following information is part of the event: .
                          Data:
                          0010: 08 00 00 00 c0 00 00 c0 ....А..А
                          Event Type: Error
                          Event Source: Service Control Manager
                          Event ID: 7026
                          Date: 10/19/2003
                          Time: 12:01:32 AM
                          User: N/A
                          Computer:
                          Description:
                          The following boot-start or system-start driver(s) failed to load:
                          st3shark
                          • #43
                            Temporary file !!
                            Operating System: Win XP
                            Burning Software: nero
                            Anti-virus Software: norton 2003
                            Where do I need to put the temporary file ??
                            Thx
                            • #44
                              Operating System: Windows XP Professional SP1
                              Burning Software: none
                              Anti-virus Software: Norton Antivirus 2004
                              Hey, i got exactly the same problem. This Windows XP install is 1 day old, so no mess.. On win2k DT ran perfectly... I'd be very glad if you could send me the workaround version.. Reinstalling DT after every reboot doesn't make me happy
                              If you need any error dumps just ask me and tell me where to find them
                              [edit]Here's the byte-dump:
                              0010: 00 00 00 00 c0 00 00 c0 ....А..А
                              [/edit]
                              Phortje
                              • #45
                                Operating System: XPSP1
                                Burning Software: Nero6
                                Anti-virus Software: Norton AntiVri. 2k4
                                Hey, Im working with DT for a long time and it always worked fine but since 3.41 this f*cking Error keeps trucking trought my head! :evil:
                                So is there a fix for that prob. or do you know what is this Error about?
