Vista 5744
    Haha, after getting it to run on my system, I upgraded to build 5744. DT gave me the initialization error so I proceeded to do the same thing that I had done before to get it working. No go. This time around setup just says "You must reboot after previous operation". LOL.
    And this time around, windows won't let me remove any of the registry values; it just tells me access denied when I attempt to remove. And rebooting into safe mode didn't work either.
    Oh well, it gives me something else to get fixed in vista.
      Do NOT upgrade with Daemon Tools and SPTD layer installed!
      To get it working now, you must remove SPTD layer, reboot, then delete SPTD key in registry Services hive (change/enable permissions of SPTD/cfg key if you get message of missing permissions), reboot, and then re-install.
        I forgot to uninstall, so was in a bad shape. I found that even by taking control of the reg key I still could not delete it (owner, full permissions etc), however, by starting device manager (devmgmt.msc) and then view / show hidden devices, under the non-PNP devices was listed SPTD, which I uninstalled, rebooted and was then able to install DT. Finally, it all worked with RC2.
        ttfn
        David
          Got the exact same problem and unable to clear it. If you get anywhere please give me a yell .
            ttfn
            David
            Sure, if SPTD is still installed/running it protects its key against unauthorized access, thus you can not delete it, you must remove SPTD service first.
              Problems in Vista RC2 5744
              just upgraded my RC1 to RC2 build 5744, but now my old daemon installation wont run, cant even uninstall it.
              So I downloaded the new 406 which is supposed to be working with Vista, but after clicking the I agree button in the installation I get the following message :
              This program will install SCSI Pass Through Direct (SPTD) layer on your computer.
              WARNING - SPTD is not compatible with kernel mode debuggers (SoftICE, WinDBG etc.)!
              Please cancel setup if you plan to use kernel debugger on this machine.
              I press OK and the installation just closes down..
              I did upgraded Vista by having the RC2 iso mounted in daemon (which was working fine in RC1), can this have something to do with it?
                I told you the same story in another forum... Fresh install and you won't have any problems
                http://bsfkillaplace.runboard.com/
                  So youre telling me this problem have no solution?
                  exept reinstall
                    There is a bug in the windows upgrade process that causes sptd to become deactivated. Sptd dev team is aware of issue and should hopefully have a fix soon.
                    A workaround is to delete HKLM\SYSTEM\CurrentControlSet\Services\sptd key, reboot, and reinstall dtools/sptd.
                      I cant delete that key, it just sais : Cannot delete sptd: Error while deleting key
                        Take a look on page 2 of this thread.
                          Anyone sussed an answer to the "You must reboot after previous operation" problem ?
                            I did upgraded Vista by having the RC2 iso mounted in daemon (which was working fine in RC1), can this have something to do with it?"
                            ok im having the same issue and also the issue of not being able to uninstall or dtool or install it i fixed the error message and not it will let me run the install but now i get this message
                            tried everyhting everyone had suggested and now im just frusterated
                            if anyone has a salution nows the time llllloolllll
                            thats a laugh of frusteration (sigh)
                              enigmatai, see my post above.
                                thanks Andareed iv read it it just doesnt seem to work so what now? do we just wait untill the sptd bug issue is resolved with vista? or am i not doing somehting right?
                                i dno but you guys a are awsom everyone here trys there best to help its real cool thanks in advance for any and all help time and consideration anyone here has to offer.
