"Unbreakable" Securom?
  • #61
    "Original disc could not be found or authenticated."
    As the SecuROM "error" stipulates, it is a bad image...
    You could also try using blindwrite 6 to make an image.
    Mail:
    curerom @ daemon-tools.cc
    • #62
      I have made three more attempts using the Alcohol 120% settings prescribed in this thread, and two using Blindwrite 6; none have borne any fruit and all are still giving the same error message.
      I am going to try burning a DVD with the image file and see if that works.
      • #63
        (It didn't.)
        • #64
          If image doesnt work it is normal that burned image also doesnt work.
          • #65
            Is there anything else I can try then to get a "good" image?
            • #66
              @Blazkowicz - Mostly your right but there is exceptions like a few Starforce Games where Image dont work but burnt on DVD with right Topology does work, so for 1 percent of a hundred maybe its worth a try
              But never heard of something like that on Securom jet
              @Theras - The new YASU 1.0.2b might work if you havent tried that jet (but I supose you have) if so theres only one more way I can think of but thats not point of interrest here
              • #67
                4.08 runs 1.02 neverwinter nights 2 without problems and i dont need to disable my otical drive
                • #68
                  Originally Posted by Blazkowicz View Post
                  Your image is bad, recreate your image with Alcohol 52/120% with SecuRom 4/5 profile and 1X DPM speed (if on cd), if on dvd select data position measurement high and speed 1X.
                  Hi, i have some problem regarding Resident Evil 4 too and i have the same problem ( "Please insert the original CD instead of backup".) I have noted that recreating image will help to solve the problem. But i'm a newbie in this scope, can u provide me with more details? Reallly appreciate you help.. =)
                  Just for your information, i'm now using the latest version of daemon and yasu. But it still cant work.
                  • #69
                    well, how did you make your image?.. easier that way, then we might be able to tell you where you went wrong...
                    • #70
                      Sorry. This error . I tried to make the image with securerom 4/5.
                      BTW When I mount the image i should be able to install the game anyway but the installation doesn't start at all not if i click on SCDAAutoRun.exe and neither by clicking the setup.exe in disk 1. It's strage I read that many others did. Does this depend on the version of DT or on the image?
