Page 3 of 6 FirstFirst 12345 ... LastLast
Showing results 21 to 30 of 52
Thread: making DVD mini image from Safedisc 4.70.000
  1. #21
    10.11.2006
    1
    im a compleat newb in this area and would like some help.. i have a vcd(virtual cd image) of battlefield 2142 now, how would i go about getting it to run with out having to have the actual cd, do i need to get deamon tools, and scrap the vcd and make it an iso, and if so what would i need to run/do to make it wourk with out an cd
    Thanks
    edit by admin: Please don't double post. The forums are moderated which is why your posts don't show up immediately.
  2. #22
    Master
    Jito463's Avatar
    24.05.2005
    1,626
    What program did you use to make the image, and what settings in that program did you use?
  3. #23
    21.10.2006
    26
    if someone told me how to scan the DVD to see what parts the SD was scaning, and how to make it smaller image.
    will be willing to help. just need guidance.
    Regard Solway
  4. #24
    Hi,
    i have good news, on Vista Rc1 deamon tools working perfectly with full imageof BF 2142... On the other hand on my other computer with XP SP2 without (Dual Layer DWD) it gives error message..So I have a conclusion that safedisk is checking if you have Dual Layer DVD or not.. unless you have Dual Layer DVD it blocks you from the game launch directly..
    or maybe it has something to do with Vista, i dont know..but i can play online without DVD...
  5. #25
    Quote Originally Posted by zack1701
    iSo I have a conclusion that safedisk is checking if you have Dual Layer DVD or not.. unless you have Dual Layer DVD it blocks you from the game launch directly..
    Wrong.
    Right, for Windows XP just disable your optical drives.
    22.11.2006
    2
    is there a beta version available that can emulate safedisk 4.7 ? I want to play 2142 without having to grab my DVD all the time.
  7. #27
    Current version does work with Battlefield 2142, just disable your real drives.
    22.11.2006
    2
    So I have to pull out all my IDE devices... what if my XP is running on IDE harddrive ? or is there a way around this (I assume this is what u mean)
    if thats the case ill have to keep using the dvd
  9. #29
    I meant your optical drives (cd/dvd drives)
    08.12.2006
    1
    Default hmmm
    I got mine working WITHOUT having to disable my Optical Drives, here's what I did:
    1) Had 2 Optical Drives enabled and 2 Virtual Drives, mounted full .mdf/.mds image - DIDN'T WORK!
    2) Disabled Optical Drives via Device Manager - DIDN'T WORK!
    3) Restarted PC, disabled Optical Drives via BIOS, Optical Drives still disabled via Device Manager - WORKED!
    4) Enabled Optical Drives via Device Manager - STILL WORKING!
    5) Restarted PC, enabled Optical Drives via BIOS, Optical Drives already enabled and working - STILL WORKING!
    6) Restarted PC one more time to make sure - STILL WORKING!
    So in my case, BF2142 only worked AFTER I disabled Optical Drives via BIOS.
    Note: I am using Daemon Tools V.08HE and BF2142 patch V1.06
