Demo executing problems
  • Demo executing problems
    Hi, I wanted to ask for some help.... I am recently having problems with demo versions... Everytime I try to execute it gives me the don't send error message... This hapenned with Call of Juarez, FEAR XP, Just Cause and even with the Timeshift demo..... Maybe someone knows how to bypass these problems.. I would be very thankful
    are you sure it is the fault of Daemon-tools???
    try to update youre drivers (grapic-cart and stuff)
      I read somewhere about that.... I don't think that this is a driver's fault.... Of course, I can't say that it is definitely DAEMON's fault... i just want some help... I have got the same issue with the older demos like Project Snowblind
        well you can find out for yourself, uninstall daemon tools, then try running the demos, see what happens, then you can reinstall if you like, that way you can say definately if it is daemons fault or not...
          I uninstalled Daemon tolls but it still doesn't work... Loks like ther is a problem with kernel32.dll... Any suggestions?
