Neverwinter Nights 2
    Doesn't detect cd
    My NWN2 doesn't detect the cd at all. It simply asks me to insert a disc.
    Anyone know why that might be?
      I think, your image ist bad. look at copybase.ch to find a good mds.
      Schreibt mir eine PN!
        A bit more accurate: Look here.
        MfG, Benni
        Mail: benni@copybase.org
          the file from your link is called "NWN2.B5T" what should I do with it?
          I've tried mounting it with Daemon 4.08HE, but it doesn't work
          When I tried the mini image from poseden, I've got
          "Emulator detected!
          Please deactivate virtual drive and emulation software." I don't installed any clone cd or stuff like that, I tried NWN2 1.02 and 1.04 polish with YASU 1.07, 1.1 and Daemon 4.08HE
          Also i added NWN to my exception list for the windows firewall.
          Any thoughts what should I do?
            Do you have BlindWrite installed?
            Did you tried the newest version of Yasu [v1.1.7033]?
              I don't even know what BlindWrite is :P
              Yes, I've got and tried the newest version of YASU(1.1.7033)
                Make an alc 120% image without dpm scaling or what ever the name is.
                Then replace the mds file with this one
                hopefully it is the same as the german dvd?
                5,79 GB (6.228.180.992 Bytes)
                  Although my image size was different (4,14 GB (bajtуw: 4 454 252 544)) I replaced the .mds and it works
                  I don't know how it's possible, but really thanks man
                    well, no problem
                      Just registered to say, thanks this works. Create a new image file in alchol 120 then swap the mdf for that one above and mount in DT4.09 with full emulation. and Neverwinter Nights 2 1.06 works a treat
                      No need to use YASU
                      thanks again
