Page 3 of 3 FirstFirst 123
Showing results 21 to 23 of 23
Thread: DAEMON Tools 4.0.8 killed my DVD device
  1. #21
    System Restore has the SPTD restore point but when I initiate a system restore, after restart it says that the restore was unsuccessful and no files were changed.
    An older restore point says the same thing.
    Vista Ultimate
    Dell D620
    DVD/CD Combo: TSSTcorp DVD+-RW TS-L632D ATA Device
  2. #22
    19.09.2007
    3
    Default How do you remove SPDT?
    I found a fix for the problem but the problem has recurred once so far, even though DT is uninstalled.
    I used the following REGEDIT:
    REGEDIT4
    [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
    "UpperFilters"=-
    "LowerFilters"=-
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdr4_2K]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdralw2k]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdudf]
    [-HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\UdfReadr]
  3. #23
    I solved my problem with a different registry edit.
    I got the following information first from this forum: http://club.cdfreaks.com/f105/tsstco...-vista-215309/
    And then I followed this link to the microsoft site: http://support.microsoft.com/kb/314060
    Basically, I just deleted the UpperFilters and LowerFilters registry entries. Then I got my DVD drive back in Computer and it seems to be working fine.
