Tom Clancy's Rainbow Six Vegas 1.01
    you can backup your registery first as follow
    1.rt click mounted_devices and export and save the reg file
    2.add the following line to reg file as follow
    [-HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices]
    so it look like
    Windows Registry Editor Version 5.00
    [HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices]
    "\\DosDevices\\C:"=hex............................ ..........
    3.after playing just click the reg file
    4. do as i sayed before
      Nah, keys deleting is not really the way forward, I'd rather use my original disc again than messing with my devices.
      Turns out that the "trick" I posted works also on my machine, which is cool.
      Though I'd rather have a new YASU
      If the minimum wasn't acceptable it wouldn't be called the minimum.
        where can I get the MDF/MDS file? I installed the game.. etc etc. I have the MDF file but cant seem to figure out where to get a mds file for it. I try to load w/ DT and the YASU (all updated versions.. even let the game update.. couldnt get it to work w/ 1.0 anyways). Says.
        "Please insert the original disc instead of a backup (1000).
        Please have a look at http://www.securom.com/message.asp?m=copy&c=1000 for further, more detailed information."
        Any ideas. I've done all other suggestions on in this post and to no avail.
          Remake your image from your original disc and you'll have the MDS and MDF files.
            I dont get it
            I tried like that with an selfmade backup-image from my DVD:
            D:\ is my daemon's virtual drive,
            L:\ is my Real DVD drive,
            and
            F:\ is where my Backup Image is...
            My Regentry is the following:
            \DosDevices\D.L:
            or should it be:
            \DosDevices\D.F:
            My Backup mdf/s is in a seperate folder, i hope thats ok...
            I also applied the Patch.
            Still says that i have to put the original DVD in, yes, i use YASU and all that fancy gatchet stuff, i HAVE read how to mount the Backup-Image, its just about the Regstuff.
            Thanks in advance!
            Mod your World, since they will never get you
              or you could try Y.A.S.U 1.05...
              hxxp://www.download.curerom.net/YASU_105.rar
              Mail:
              curerom @ daemon-tools.cc
                Once again, you are the man sYk0
                  i think my problem may be different than everyone elses, but i get the securom error 7000
                  but when i run yasu, it says no securom devices to hide
                  i just d/l'd and installed DT 4.08, and am using yasu 1.05
                    What is the exact error message? I don't have a clue what error 7000 is.
                      SecuROM,Sony,Sony DADC,copy protection,cdrom,disc,dvd,dvd copy protection
                      Should be security modul.
                        Could they still "upgrade" their security/copyprotection? Because R6V Patch 1.02 is on its way
                          It was released yesterday, I downloaded it at 3dgamers.com. No problems using YASU 1.05
                            error
                            none of the steps are working for me... using newest d-tools and yasu 1.05...
                            yet i still get an error about a back up disc
                              That error means you've got a bad image. What program and settings did you use to create the image?
                                hi guys,
                                i used dameon tools v4.06, and mounted image, then used yasu1.05 but it never worked. game didnt run and i got this error message
                                i keep gettin this and have no idea how to solve this issue,
                                thanx in advance for ne help
