Error DT does not recognize scsi drive
  • Error DT does not recognize scsi drive
    It appears in a small box with a small red cross in it and tells me that DT does not recognize the scsi drive, when I start DT automatically. When I press ok DT changes from a red icon in the system tray to a green icon in the system and all the drives work ok, mounting and playing as they should.
    Is there any way to loose this error message, without removing DT which works just fine ,after a long episode of getting it to install in the first place.
    Maybe someone might know a registry fix to stop the error message?.
    Running XP pro 32bit
