Showing results 11 to 20 of 21
Thread: Yasu
    27.09.2005
    822
    grabbed 1.06, it crashes, bad parameters passed on the stack
    crashes @ .401BEE.. mov dword ptr ds:[eax], edx
    eax = 03
    edx = 36
    access violation (obviously as 03 isn't a good area of memory to try and write to)..
    os: xp32 sp2
    didnt try any commandline params...
    if its of any help, it only seems to happen when i try running the exe the 2nd time
    (to restore), and that i have all drive letters in use, and my last 3 drives are network maps.. hopefully that might aid you in reproducing it, issue also does not happen on my vmware win2k sp4 system
    also when executing it the first time the messagebox does not appear that reports what drives were hidden...
    sYk0's Avatar
    27.12.2005
    392
    Does anyone else have this (above) problem?
    Mail:
    curerom @ daemon-tools.cc
    Quote Originally Posted by sYk0 View Post
    I am having a similar issue with an error from yasu.
    I had run 1.04 to hide, without unhiding, I ran 1.06. everything seemed ok, until I tried to run the game, R6. then Yasu crashed.
    let me know if there is more info I can provide.
    thx
    When I try to run yasu, I get an error "YASU.exe has encountered a problem and needs to close."
    the error signature offset is 00001bee. and this is on xp.
    and now every time I try to run yasu, I get the same error message. even after I reboot, and enable and disable daemon-tools.
    let me know if you need more info.
    27.09.2005
    822
    Quote Originally Posted by Sixpackd View Post
    "YASU.exe has encountered a problem and needs to close." the error signature offset is 00001bee.
    Add base address = 401BEE = same issue as mine
    also, is this forum moderated?, cos my original post didnt seem to appear
    yes, this forum is moderated, however, there was a glitch in
    user-rights, therefore your post doesnt appeared immediately,
    is corrected now
    sorry for any inconvenience
    27.09.2005
    822
    cheers chief , hopefully we can help syk0 sort this soonish
  8. #18
    sYk0's Avatar
    27.12.2005
    392
    Try this hotfix from Microsoft see if it helps...
    http://www.microsoft.com/downloads/d...displaylang=en
    It may be a problem with the Windows Vista section in the exe's manifest.
    Mail:
  9. #19
    looks like its still an issue for me, even after I run the hotfix and reboot. everytime i run YASU 1.06 I get the error. also after the error happens, it seems that rundll gets hosed, so that every time I shutdown, it gives me that message saying trying to close rundll, or something like that.
    ps. check your daemon-tools.cc email
  10. #20
    i already had that update windows update automatically downloaded it ages ago getting same offeset error Offset: 00001bee
