YASU 107 crash windows XP.
    Same as nomisq for me.
    When I start yasu, I can move the mouse, but not click anything, and nothing happens when pressing ctrl-alt-delete. Only thing that helps is a hard reset.
    Running xp with sp2, X2 5000+, 2gb ram, 7900 gtx.
      sorry, did not find any edit buttons to edit my previous post.
      Anyway, it seems like older versions of yasu does not work either, I just tried the 1.05 version and I got the same result.
        new version of Y.A.S.U (v1.1.0) will be released shortly, hopefully this addresses the issues with Win XP SP2
        Mail:
        curerom @ daemon-tools.cc
          How short is shortly? :wink:
            Usualy "when it's done"
            Carpe diem
              Hi, i have a questions for you
              i use windows 2000 pro sp3 and i have try yasu 1.07, but when it load appear the follow message:
              yasu was unable to hide any devices for securom 7.x, this may due to insufficient user privileges.
              I run yasu from administrator account with all privileges.
              Can you help me?
              Scuse me for bad english
                along with the crack it came with
                Um, you do know that this is illegal...!
                Mail:
                  The problem I am facing is the following:
                  I have the latest daemon tools 4.08 + sptd 1.42 + yasu 1.07...
                  I load an image with daemon and when I run yasu, the computer freezes, the mouse can move but cannot select anything and the only key from the keyboard that works is the sortcut for the start button...
                  Is it possible that the problem occurs because I have a usb keyb and mouse?
                  is there something I can do to fix this?
                  My specs: pent IV 3,2GHz, win xp(32bit) sp2, 1gb ram, 6800gt
                    I have the exact same problem. Is there no fix for this issue?
                      I'm also in the same situation
                      This is the exact same problem as mine, is there no fix for this? Many of people are having the same problems yet nothing has been said for a solution...
                        yasu crash
                        i use norton internet security 2007.. i have the same problem
                          I have the following problem
                          I have the latest daemon tools 4.08 + yasu 1.07...
                          when I wait a moment and hit STRG+ALT+DEL a screen appears and tells me that the drives have been hidden etc.
                          but the pc is still frozen sometimes when I hit STRG+ALT+DEL again the screen disappears I and yasu works (but I have only a chance of 10%) or nothing happens (90 %)
                          I use win xp sp2, gadata antivirenkit, daemontools, alcohol
                            Hopefully this will be sorted out in Y.A.S.U v1.1.0
                            Mail:
                              I've solved the same problem having deinstalled Roxio Drag-to-Disc which was a cause of this.
