Running Daemon Tools in D: drive?
  • Running Daemon Tools in D: drive?
    I am using Daemon tools to install a CD onto my computer, and it works great, but when I try to open the CD, it gives me an error saying I need the CD to be in the regular CD-ROM drive. My question is;
    Can Daemon Tools run a CD as if it were in the D: drive?
    Is there some program that can change a CDs reading of the path is should run on?
    Or should I just burn it onto a real CD and use that. But I was wondering in that case, if I burnt a CD would I have to put it in every time I play or could I use Daemon Tools or another tool to run the game without the CD?
    Sounds like your image isn't good enough. What program did you use to create the image and what settings did you use? Also, you may need an anti-blacklist program such as YASU.
