Page 2 of 5 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 45
Thread: YASU doesn't work on Test Drive Unlimited
    Default still doesn't work!
    I installed Test Drive unlimited from an .mds file. when I try to run it, I've got the same message as above. I installed YASU, then I had the same problem: the program disapears afer 10 seconds.
    I've seen on this page that it could be useful to install SPTD 1.42 but after installing and rebooting, it doesn't change anything: the program disappears after 12 seconds !
    any other solution???
    yeah... 1.42 and dt 4.08he with yasu 1.07 doesnt work...
    i want wo play without that loud running dvd
    Kinlaadare's Avatar
    24.05.2005
    697
    Are you sure the image is done well? Mine is running smooth and ok (well, smooth will be when nVidia will have optimised its vista drivers)
    Carpe diem
    Thorandor's Avatar
    03.11.2005
    123
    Quote Originally Posted by Kinlaadare View Post
    .... (well, smooth will be when nVidia will have optimised its vista drivers)
    Hehe you know that
    As to TDU, most likely your image is bad, recreate it and see if that's better
    If the minimum wasn't acceptable it wouldn't be called the minimum.
    my problem is, that the copy protection says to me( conflict detected with emulation software) and not could not found dvd or else.....
    thats my problem...
    and my image is well.
    blindwrite image.
    12.12.2002
    13
    @NamKa
    BlindWrite? Then try to disable EZ-Play.
    yep its all ez-plays foul
    thx
  8. #18
    Hi, im not sure if my last reply got posted. I would like to know what EZ-PLAY. im haveing the same problem as everyone else and would like to play. Whats EZ-PLAY and how do i disable it?
    thanks
    Sergio
  9. #19
    So is there a consensus on what the correct manner of running this game is?
    I mount the .mds and run YASU, it says my optical drives are hidden.
    But somehow Test Drive and its protection still say there is a conflict with the emulation software.
    Is there something in my registry that is preventing it from working, is YASU even doing its job?
    DaemonTools 4.08HE and YASU 1.07
    I might be willing to install XP on a blank drive to see if this works on a clean install.
  10. #20
    Kinlaadare's Avatar
    24.05.2005
    697
    EZ-Play is a part of blindwrite. If you don"t have it installed on your computer, then you don't have EZ-play.
    Carpe diem
