Showing results 21 to 30 of 45
Thread: YASU doesn't work on Test Drive Unlimited
  1. #21
    07.10.2006
    157
    @victorsays:
    do u have some older Emulation-programs like Virtual Clone Drive?
    Deinstall them all.
    if u still can get it working then delete following registry key:
    HKEY_LOCAL_MACHINE\HARDWARE\DEVICEMAP\Scsi
    now reboot and try again! dont forget yasu!
    cheers!
    Upgrade your programs:
  2. #22
    So still no one found the solution for the program disapearing after 10 seconds?
    there is no error message: just the program closing...
    help plz!
  3. #23
    If you are still having problems, try downloading an image from gamecopyworld,
    once you've installed the game from your DVD, mount the image from gamecopyworld onto deamon (still use YASL) - it worked for me and i was having the same problem as everyone else here.
  4. #24
    13.03.2007
    1
    I still can't get mine to work
    i have daemon 4.08 and sptd 1.42
    i have yasu 1.07
    i have a good image (mds/mdf)
    BUT the game still tells me to "insert the original disc instead of a backup"
  5. #25
    no problems here with 1.07 and 4.06HE on Vista 32Bit
  6. #26
    02.07.2006
    12
    I have no problems too, running YASU 1.07 and SPTD 1.42. The game works fine.
  7. #27
    sYk0's Avatar
    27.12.2005
    392
    Well, if your image was good then that message would not appear...
    Mail:
    curerom @ daemon-tools.cc
  8. #28
    I'm using daemon-tools 4.08HE and SPTD 1.42 in combination with Yasu 1.07. Os is Windows XP home SP2. There is no Alcohol, Blindwrite or something similar installed.
    I've tested it with my own image and the image from gamecopyworld and my hardware drive is deactivated.
    But i always get following error message.
    Code:
    Konflikt mit Emulations-Software entdeckt.
    Weitere, detaillierte Informationen entnehmen Sie bitte http://www.securom.com/message.asp?m=emu&c=6000&l=ge.
    Conflict with emulationsoftware detected.
    Further info....
  9. #29
    07.10.2006
    157
    @icebreaker: did u follow that steps:
    Quote Originally Posted by ..::shiFt::.. View Post
    [...]if u still can get it working then delete following registry key:
    cheers!
  10. #30
    yes, i have deleted the registry key etc., but it still don't works.
