Showing results 31 to 40 of 45
Thread: YASU doesn't work on Test Drive Unlimited
  1. #31
    Quote Originally Posted by ztp912 View Post
    I still can't get mine to work
    i have daemon 4.08 and sptd 1.42
    i have yasu 1.07
    i have a good image (mds/mdf)
    BUT the game still tells me to "insert the original disc instead of a backup"
    remove ezplay driver (BW)
    remove all programs that use virtual drives (escluded DT and Alcohol)
    try it (in this order)
    run yasu 1.07
    mount mds
    run exe
  2. #32
    08.03.2007
    1
    I deleted the registry key like above and i still have this message
    With last YASU 1.1
  3. #33
    sYk0's Avatar
    27.12.2005
    392
    Try this...
    Uninstall DAEMON-Tools...
    go to \Program Files\DAEMON-Tools\ delete any exsisting files...
    Download SPTD Uninstaller, run it...
    Reboot your computer...
    Download SPTD 1.42 Installer (32Bit) or SPTD 1.42 Installer (64Bit) depending on your O/S
    Install latest SPTD driver (above)
    Install DAEMON-Tools 4.08 (in the downloads section)
    Reboot your pc again...
    Hopefully this will work...
    Mail:
    curerom @ daemon-tools.cc
  4. #34
    Default Still Not Working
    ive followed everything on these 4 pages and nothing i get the EXE loaded for 2 secs and the quits
  5. #35
    Quote Originally Posted by sYk0 View Post
    Try this...
    Thank you, it works for me!!!
    I posted this is the atari forum, i reffer your name, thanks.
  6. #36
    a similar error ocurrs in silent hunter 4 with patch 1.1.
    there the procedure above didn't works for me :-(.
    http://www.daemon-tools.cc/dtcc/show...ed=1#post80242
  7. #37
    Try this...
    doesn't work for me.
  8. #38
    02.04.2007
    1
    Cannot run TDU on my computer equipped with sata burner. With YASU loaded or not TDU permanently shows the same message "Unable to authenticate original disc within time limit." Tried image on different comps all ok, but not with mine.
  9. #39
    I get the error "Please insert original disc instead of a backup (4001)" any ideas?
    I have run YASU with the latest version of DT.
  10. #40
    Click on link in my signature.
