Suggestion: .VC4 cd container file.
This topic is closed.
  • Suggestion: .VC4 cd container file.
    Greetings to you all... As my first post I suggest implementing support for the Virtual CD's .vc4 file..
    .vc4'rs are usually accompanied by .000 - .999 images depending on the number of tracks on a CD..
    Virtualize your CDs, DVD, HD DVDs and Blu-ray Discs and get the fastest possible access to your data, both locally and over the network
    Or.. perhaps easier, someone might know of a conversion tool that can process these into ISO's or other formats supported by Daemon.
    Have a continued nice day people
    Proprietery images will NEVER be supported. What's the point anyhow? Why would you want to have these .vc4 files? They only work with virtual cd i guess so they are pretty useless. Why not just reimage the file from the virtual cd drive to an iso or ccd or whatever?
      Moreover we would need the specs for that image format AND THE PERMISSION to use it. And we don't have them.
      Moreover this is already discussed in our FAQ!!!
