YASU 1.1 User Permissions Error
    thanks a lot sYk0!
    Aren't the samplescripts integrated anymore?
    You messed up with the numbers in the announcment:
    Originally Posted by sYk0
    Version History:
    1.1.3075
    cheers!
    Upgrade your programs:
      They are now integrated in the ZIP-file at yasu.copybase.ch (just re-use the link which was sent to you, if you already have one).
      MfG, Benni
      Mail: benni@copybase.org
        thanks benni!
          Originally Posted by Makou107 View Post
          So now thats it out can I get some support please on how to fix this issue? I am still getting this error.
          Error while checking user permissions... !
          I'm not using any other tool besides Daemon tools. Thanks for any help.
          think ive found a way , so test this out.
          start run regedit
          then go into:
          HKEY_LOCAL_MACHINE\SYSTEM\MountedDevices
          and see if you can see any devises
          should be like :
          \DosDevices\C:
          and so and and so on and so on.
          If you cant se any drives the permission on the mountedDevises needs a fix.
          right click it and do permissions , the user that screwed up my system was powerusers , if i denied that user rights 2 nothing (except the grey marked 1ns) i got all my drives back.
          had a coupel of mashines that did it when i had 2 get silent hunter 4 running. hope it works for you
            well - i think the latest version of YASU should fix that problem too: click.
            cheers!
