Page 5 of 5 FirstFirst ... 345
Showing results 41 to 49 of 49
Thread: Command & Conquer 3 - Wrong Disc Inserted Error
  1. #41
    A required security module cannot be activated.
    This program cannot be executed (5024).
    i get this error when using the latest DT4.08 N YASU1.1 build 7035 CNC3 1.04
  2. #42
    Moderator
    Benni's Avatar
    04.03.2005
    287
    Try to disable VSO Software EZ-Play, which comes with BlindWrite. This may be a solution.
    MfG, Benni
    Mail: benni@copybase.org
  3. #43
    27.09.2005
    822
    same happens when using the original disk?, more info helps.. could be ez-play too.. wouldn't be the first time
  4. #44
    Quote Originally Posted by evlncrn8 View Post
    Original disc will not run with blindwrite's EZ-Play on the system unless EZ-Play is both disabled and cloaked.
  5. #45
    27.09.2005
    822
    yeh, but it should show the ez-play message code thing then
    question was to see if he had the problems running from the image, or running the game at all..
  6. #46
    Quote Originally Posted by Mystique View Post
    Maybe the *.mds file is incorrect.
    Try this one from my C&C3 and use latest DT with YASU !
    I have downloaded the file and loaded to DT it says the file is not accessible. Any ideas?
  7. #47
    28.10.2005
    322
    Quote Originally Posted by Natalie Parko View Post
    You need a complete image (.mds and .mdf) and swap the downloaded one with your original. Both files need the exact same name before the dot...
  8. #48
    Default BackUP
    Normally I create a backup disk of my games so that I can put them away in a safe place and not get damaged, but it didn't work for C&C3. I normally just use Nero and it has worked every time so far except for C&C3. I used a Dual Layer disk and a my Rom can write and read them so what is going wrong? Do I need to use a different piece of software?
    Please Help
  9. #49
    Nero can't backup protected disks. Use Daemon Tools Pro/Alcohol 52/120% to create a working image.
