Page 2 of 2 FirstFirst 12
Showing results 11 to 15 of 15
Thread: Can't get YASU working
    Yeah, that's for just for Extraction point, isn't it?
    Scanning -> D:\Sierra\FEAR\FEAR.exe
    File Type : Exe, Size : 6004736 (05BA000h) Bytes
    -> Suspicious MZ Header..
    [!] SecuROM Detected - Version 7.xx
    - Scan Took : 0.657 Seconds
    07.10.2006
    157
    i don't know, did you try it? Try both extraction point and directors cut images, maybe one of them work.
    mmh ProtectionID doesn't recognize the newest Securom protections exactly in the v5.2c.
    We have to wait until cdkiller release the next version.
    Upgrade your programs:
    Oh, ok. I'll try the other images when I get home, then.
    BTW, is cdkiller another program I need to be running?
    FYI: I had previously run A-Ray Scanner with the following results.
    [10:08:14 AM] SecuROM 7.00.00.0023 detected -> F:\FearXP\Disk1\FEARXP.exe
    [10:08:31 AM] --- File(s) Scan Finished [16.43s] ---
    Running it on the Disc itself and then running it on the image gave me the same results.
    07.10.2006
    157
    cdkiller is the author of ProtectionID
    @spdygnlz
    Send me .exe from game and i will give you exact SecuRom version.
