YASU doesn't work with C&C3 1.04 version
    My team member Eric said, that SPTD drivers might have been blacklisted. Uninstalling them helped in his case. But then you have no chance to use your image. Its very strange.
    MfG, Benni
    Mail: benni@copybase.org
      I don't think that something is blacklistet because after a reboot all games are working fine.
        Can you try SPTD 1.43 beta?
        Upgrade your programs:
          Same Problem
          I am having the exact same problem. I am also running YASU 1.1.7035 and CNC3 v1.04
            Issues With Cnc3 Tw
            alright guys this is my ISSUE
            before i play the game
            i start yasu - clock for securom
            then open up daemon tools
            mount CNC3
            sometime it works
            as soon as it loads to the GREEN EA LOGO screen
            if there is sound the game works fine
            however
            if there isn't sound after the GREEN EA LOGO screen
            it jus goes to a blank screen
            is there a proper procedure for me to cloak and mount
            it gets annoying
            sometimes it works
            sometimes it doesnt
            it drives me NUTS!
              mount CNC3
              sometime it works
              however
              it gets annoying
              sometimes it works
              sometimes it doesnt
              it drives me NUTS!
              I think you are in a different case. We are discussing that we can't even go into the game. But you could go into the game, it's just might crash after the EA logo.
              The cd check and simulation blacklist detection are only when are you still in Windows. While you see the cnc3 big picture logo, and your mouse cursor will turn into a cd rotation animation. Our problem in the error right here. But your case is already pass the cd checking and simulation detection. So there is nothing to do with yasu, since yasu is a cd drive hider to prevent the game detect image simulation. It has nothing to do after the detection.
                mount CNC3
                sometime it works
                however
                it gets annoying
                sometimes it works
                sometimes it doesnt
                it drives me NUTS!
                Does this also happen with your original DVD?
                  I had an original dvd and I still received these errors...
                    You had? This mean you dont have original dvd anymore and so no support.
                      This also means the error has nothing to do with YASU.
                        so back to the topic, does the problem got solved?
                        I am still getting the error now.
                        I will try out the new daemon tool version 4.09 to see.
                          Since Version 4.09 the error never occurred to me, but I have to watch it for a few days.
                          At first when I run C&C3 with Daemon Tools V 4.09 I got the error that the Disc can't verified, but the problem was the Vendor and the Model name. Since I renamed the two names all works fine for the moment. Perhaps there was a problem with the Vendor and Model names in the old version, too.
                            No fix yet?
                            I've tried with both DAEMON Tools 4.09HE and Alcohol 120% v1.9.6.4719, running YASU v1.1.7035.
                            This worked with v1.04 of CNC3, but it suddenly stopped working?! And I cannot fix it even with restarts and uncloaking-remounting.
                              He wasn't the one asking the question.
                                Could it possibly be that it is somehow related to the amount of physical memory of the machine? I have 1GB, XP all patches as of today, DT4.09HE, YASU 1.1.7035 ... and I can cloak / uncloak / play all the day ...
                                Btw. which Versions of SecuRom does your C&C 3 have? You wonder why I am asking ... see my posting here:
