Showing results 21 to 30 of 35
Thread: YASU has probably been blacklisted (again)
  1. #21
    GERMAN TRANSLATOR OFFICIAL TRANSLATOR
    Hanschke's Avatar
    16.11.2005
    503
    0x336A find in tiny hexer but what value have i to change?
  2. #22
    to speed this up, I'll write this in German. If anybody is interested, I'll write another howto in English later, when I have more time.
    auf der rechten Seite des Hexeditors kannst du in der Zeile beginnend bei Offset 3360 "bçÿHø832wRY.A.S." als ANSI ASCII-Version der Hexdaten links lesen. Klick auf das Y und dann den Buchstaben, den du einsetzen möchtest oder gib links im nun markierten "59" einen anderen Wert ein (z.B. 58 für X). Speichere die Datei.
    Fertig
  3. #23
    Hanschke's Avatar
    16.11.2005
    503
    hrhr very easy thx!
  4. #24
    Can you please write it in English, because I need it sooner rather than later? I'm not as good at speaking German, as English, and I don't want to mess up YASU.
  5. #25
    I hope Mephisto18m isn't annoyed if I do it for him?
    on the right side of the hex editor you can read in the line at offset 3360 "bçÿHø832wRY.A.S." as ANSI ASCII-version of the Hex Data on the left side. Click on the Y and type in the letter you would like to have there or you type in another code on the left side where the "59" is marked (f.e. the 58 for zhe letter Z)
    Then save the data and play
    (Sorry for my not so good english )
  6. #26
    thanks, saved me the time I'd had spent just now.
    "f.e." isn't used in English though. Use "e.g." instead.
  7. #27
    Moderator
    Benni's Avatar
    04.03.2005
    287
    There will be a new YASU release very soon.
    MfG, Benni
    Mail: benni@copybase.org
  8. #28
    hush
    still good to know how you can do a self-made anti-blacklisting
  9. #29
    Hanschke's Avatar
    16.11.2005
    503
    benni u can make a spoiler?
  10. #30
    I doubt sYk0 would like that.
