Page 2 of 2 FirstFirst 12
Showing results 11 to 16 of 16
Thread: "handmade" GUI for DT
    27.09.2005
    822
    most of its the same, high level languages (c/delphi/vb) all follow the same constructs, you'll see if you look at some source code, like on the site i pasted, theres tons of examples to work from and play with... best way to learn it is to just experiment...
    stay away from c++ at the moment, just focus on c (no :: crap, or virtualisation of procs/objects and so on)... should take u next to no time at all...
    Yeah there are much parallels between these languages. I also taught myself java with the java-docs and some other things and it wasn't so difficult (if you understand english). Now i'm doing the same with C/C++ and i can use some things which i learned with java also for C/C++. ATM i pretty like Java.
    31.05.2007
    13
    thank u evlncrn8 for motivating me to learn by myself other languages!!!.
    I tried c#.NET and here is the result:
    http://rapidshare.com/files/38430152...I_c__beta1.exe
    not anything special but i believe it is worth a download
    also, it doesn't need a batch file in order to be run as it gives the commands directly to daemon tools.
    i am looking forward to any feedback
    echo_03
    P.S. ppl who still use the vb version please download it from here: http://rapidshare.com/files/36125343...n_frontend.rar
    thank u
    sYk0's Avatar
    27.12.2005
    392
    I'm busy making a GUI for DT (standard)...
    Can't give more info about (if you are a customer, you should know more about it)...
    Anyways... VB (non .NET) is not such a bad language, thats where I started many many years ago...
    I've scince then found delphi (pascal), what I love about delphi is that, it's very fast to make apps in...
    I don't want to start a debate about which language is best, they are mostly pretty much the same nowdays, with the exception of DirectX and OpenGL the prefered language is C.
    Edit: Could you perhaps upload you app(s) to another file sharing server (RapidSahre sucks donkey b4lls)...
    Mail:
    curerom @ daemon-tools.cc
    31.05.2007
    13
    Quote Originally Posted by sYk0 View Post
    any suggestions for a server???
    27.09.2005
    822
    glad u actually tried other languages, personally c# would not have been my first choice, i'd have gone with c or something like delphi as syk0 mentioned, simply because .net has a large overhead (ie: the framework requirements).. its a good starting point though
