Showing results 31 to 40 of 47
Thread: Command and Conquer Patch 1.05
  1. #31
    Moderator
    Benni's Avatar
    04.03.2005
    287
    Command and Conquer 3 Version 1.05 / Windows Vista Business x64 / YASU 1.2b 7060 / All DT Emulations off / VSO EZplay not installed / VCD9 not installed
    Playing with Game Disc (YASU enabled): A required security module can't be activated. Execution of this application failed. (translated, original message is German) - Error Nr. 7001
    Playing with MDS Image (YASU enabled): A required security module can't be activated. Execution of this application failed. - Error Nr. 7001
    Playing with Game Disc (YASU disabled): The game starts.
    Playing with MDS Image (YASU disabled): Conflict with emulation software.
    It all worked perfectly with patch 1.04, now I have to use my original disc.
    MfG, Benni
    Mail: benni@copybase.org
  2. #32
    sYk0's Avatar
    27.12.2005
    392
    Try using Y.A.S.U with the parameter "-usuck"
    i.e. "YASU.exe -usuck"
    fyi, the parameter is only for use with YASU 1.2b.
    Mail:
    curerom @ daemon-tools.cc
  3. #33
    Moderator
    Benni's Avatar
    04.03.2005
    287
    Hi sYk0,
    doesnt work. That command line parameter hides the tooltip of YASU, doesnt it?
    But still the same message for me :-(. Security module couldnt be loaded... etc.
    MfG, Benni
  4. #34
    Quote Originally Posted by Reef View Post
    You're not using the latest YASU. Get 1.2b here.
    Thanks but I tried that last night bro. Still no dice for me, i tried the same combinations of renaming etc. The official C&C3 forum has a thread about it. Might be some more info in there.
    http://forums.ea.com/mboards/thread....32410&tstart=0
  5. #35
    Moderator
    Benni's Avatar
    04.03.2005
    287
    English
    Read this:
    http://forums.ea.com/mboards/message...&sls=2#2314829
    German
    An alle, bei denen es nicht mehr funktioniert:
    Start => Ausführen => regedit (eintippen, bestätigen)
    Den Schlüssel
    Code:
    HKEY_LOCAL_MACHINE / SYSTEM / MountedDevices
    aufsuchen.
    Darin alle blauen Einträge löschen (alle REG_BINARY-Einträge). Anschließend muss ein Neustart gemacht werden.
    Das ist eine Lösung aus dem C&C3-Forum von EA, die bei mir funktioniert hat!
    Edit
    WARNING: Devices will be reassigned to their drive letters. So you might have to re-order them manually in the devices management panel of Windows.
    Warnung: Die Laufwerksbuchstaben werden nach diesem Vorgang neu zugeordnet. Möglicherweise muss das in der Computerverwaltung beim Datenträger-Management rückgängig gemacht werden.
    MfG, Benni
  6. #36
    GERMAN TRANSLATOR OFFICIAL TRANSLATOR
    Hanschke's Avatar
    16.11.2005
    503
    have u testet it? i dont want to do it
  7. #37
    Moderator
    Benni's Avatar
    04.03.2005
    287
    Of course.
    MfG, Benni
  8. #38
    27.09.2005
    822
    other warning -> you might bsod if you do this (some controller chipsets/drivers poll this registry key).. so reboot as soon as you can after deleting the keys..
  9. #39
    07.10.2006
    157
    I guess thats a SecuROM bug, as it can happen with the original DVD inserted in the physical drive too.
    Upgrade your programs:
  10. #40
    27.09.2005
    822
    well, securom 'recommendation', doesnt necessarially mean its their bug... windows is weird sometimes too
