Showing results 1 to 4 of 4
Thread: Ancient wars: Sparta problems :(
    Reden Ancient wars: Sparta problems :(
    I got problems running Ancient wars: sparta... I have mounted the ISO-file and i currently use the latest Yasu and DT.
    BUt still it does'nt work... Mayby you got a suggestion?
    Dont mount ISO files. Click on link in my signature.
    Hey, thx for the reply. Since I'm quite a noob would you mind describing what I should do a little more specific, in a simple way?
    Download Alcohol 52 % free edition and install. After install and restart (it is possible you have to run installer again after restart). Then start program and goto image wizard and do as i said in link. Then use YASU (yasu.copybase.ch) and cloak virtual drives. Now game should start.
