Incompatibility : daemon tool + intel raid driver 7.x on ICH8R
    Do not worry, Intel RAID prob will be fixed soon.
      If you fix it I will have your babies!
      My computer is a glorified media player until I can access my images....
        QFT..
        X(
        -filler?-
          Has there been any progress ?
            Same issue here with latest atitool pro advanced, mounting a 6 Gbyte image on the IDE emulated drive.
            The difference is my ICH9R of a X38 chipset.
            I hope that a solution is near......
              My machine had some random and frequently freezes after windows start.
              Gigabyte DS4 (P965/ICH8R)
              Using DAEMON Tools 4.10 Pro
              ACHI Activated with Intel Matrix Storage 7.5
                Throw us a bone wouldcha devs .
                  Any news on a fix?
                    Problems with images on ICH9R RAID
                    I've detected similar problem on following systems:
                    MB: Gigabyte P965DS4
                    RAID 01
                    CPU C2D
                    DT: 4.10
                    MB: Gigabyte P35DS4
                    RAID 1
                    CPU C2D
                    DT: 4.10 Pro
                    MB: Gigabyte P35DS4
                    RAID 5
                    CPU Quad
                    DT: 4.10
                    Some images are mounted without problems, but when trying to mount miniimage (20MB->6GB) DT freezes and after few seconds WXP SP2 freeze as well. There is no major CPU or Memory consumption increase before freeze.
                    Mounting image from disc other than RAID (USB, Network, ...) does help and miniimage is mounted in a second.
                    On computer without ICH9 there is no problem to mount that image.
                    Any news on fixing this nasty prob?
                      I'm having similar problems (frequent freezes when IDE virtual drive enabled, frequent freezes on some of the cd images) on my laptop.
                      Toshiba A200-1MA (ICH8something southbridge (Santa Rosa platform))
                      Vista Business
                      DT 4.10 pro
                      Is there any other cd/dvd emulator that can emulate an IDE drive? I need something until the bug'll be fixed.
                        Experiencing Same Problems
                        iIm confirming the problems also.
                        My Rig:
                        Asus P5K3 deluxe Bios 0604
                        Intel Quad Core Q6600 @ 3.6Ghz
                        2x 1G Kingston DDR3 1375MHZ
                        1x Ati Radeon HD 2900xt 1024Meg DDR4 Mem @ 2100Mhz Core @ 850Mhz
                        4x 160Go 2x Raid 1 (Dual Boot WinXP and Vista Ultimate)
                        2x Raid 0 (Game and Image Drive)
                        Im running Windows XP sp2, WIth Deamon Tool Pro Advanced4.10.0.218 with SPTD 1.50
                        My Images are located on a Logical Volume in Raid 0 on a Intel Raid Matrix Controller (Intel(R) ICH8R/ICH9R SATA RAID Controlor Driver Version 7.6.0.1011)
                        So far all image are working.. except one.. Which makes my computer lockup instantanously when ever i mount this image in a Virtual IDE CDrom Drive.
                        Here's a Temporary Work Around..
                        I've Place the image (The Witcher) on a external USB Drive / Network Drive and mounted it and it passed without locking my computer.
                        i Hope this might Help Others while the Developpement Team at Deamon Tool can find the problem
                        Best Regards..
                          I hope a solution will be found near.
                          I have this bug since 5 mounth... and my pc freeze 15 minutes each day...
                            Try to install SPTD 1.51 beta as according to changelog they have something done regarding this problem.
                            http://disc-tools.com/download/sptdbeta (Fixed issues with Intel RAID controllers)
                              Thank You Blazkowicz i install stpd beta and it works for me try to install it and disable dt pro agent. Once again THX! blazkowicz
                                The 1.51 fixed it for me, thanks a lot guys!!!
