Showing results 11 to 20 of 21
Thread: Age of Empires Collector's Ed. DVD
    Quote Originally Posted by xileF1337 View Post
    if this doesn't work your DVD drive is probably unable to extract a good DPM (don't ask me why the other disc worked ).
    did you check the quality of your DPM?
    It doesn't work :-(
    It worked once, but the game crashed and I haven't been able to start it since.
    I have tried with some other games and they work just fine...
    I tried MDS Viewer and the graph looks like an U shifted a little to the right and the top-left part is a little fuzzy. What should a good MDS look like ?
    I realy appreciate you efforts here :-)
    Skull
    On normal DVDs it should look like the left halve of an 'U' (a falling curve. It looks like the function f(x)=|x^-2| if you like maths ). But in your case it looks like a streched 'U' becouse your original DVD is a double-layered disc (the rising curve is the second layer).
    The graph should not be fuzzy. The more fuzzy it is, the worse is the quality of your DPM.
    I think you problem is that your drive can't extract proper DPMs from double-layered discs corrrectly. Supposeably using another one (e.g. use your burner) or upgrading the firmware of your current drive will solve your problem. You could also search the internet for a proper MDS data.
    Ok, thanks for explanation and the math :-)
    I tried to make the image on my second computer which is exactly identical (I bought two at the same time). And now I got a working copy As I said, I bought two identical computers at the same time, and the second one has an exact cloned hard disk from the first one, so I have no idea why it works on one computer and not the other one
    Re. Searching for a good MDS: Am I getting this straight that my first, non-working, copy could have worked if I just found a good MDS? And I could have saved all this trouble?
    Well, it works now and I really appreciate your help
    Skull
    Yeah Reading the files on the disc is no problem for DVD-(+)DL-drives, but some optical devices can't extract a good DPM (with an unfuzzy graph ). So downloading an mds file which contains a working DPM would had solved your problem, too.
    Well, it works now and I really appreciate your help.
    No problem dude
    PS: The domain of the graph is X≥0
    Kinlaadare's Avatar
    24.05.2005
    697
    Just to add on the math side, |x^-2|=x^-2 whatever the x' value in R* (not true if x is complex)
    Carpe diem
    Goenk's Avatar
    12.10.2005
    214
    Quote Originally Posted by Kinlaadare View Post
    Isn't it just 42!
    Mistake of mine, sry The function is
    f(x)=xˉІ
    x must be element of R and the domain is x>0.
    @SkullStalker: Now you can draw a perfect function graph and compare it with your DPM
  8. #18
    23.03.2004
    547
    Quote Originally Posted by Goenk View Post
    Isn't it just 42!
    Agreed!
  9. #19
    You need high precision (click on link in my signature).
    I can't click on the link. I've also got age of empires collectord edition. I've created a disc image using the securom settings but when I mount the image it won't run without the disc. Please help me
  10. #20
    could somebody give me there working mds file. Mine doesn't want to run without the disc. I've created other disc images that work fine.
