Page 1 of 3 123 LastLast
Showing results 1 to 10 of 21
Thread: Age of Empires Collector's Ed. DVD
    Default Age of Empires Collector's Ed. DVD
    Hello.
    I have bought subj. which includes AoE + Exp. + AoE II + Exp.
    A-Ray says that the DVD is SecuROM 7.00.00.0003 protected, so I used Alcohol to make an image with DPM (Normal @ 2x).
    But when I mount the image using Daemon and try to start the game, I get the following error: Please insert the original disc instead of a backup. I have tried with an dwithout YASU without any luck :-(
    Any ideas ?
    Thanks in advance
    Skull
    You need high precision (click on link in my signature).
    Oh happy days ! That worked :-)
    Thanks a lot.
    Can you help me with Rainbow Six Vegas as well ?
    Or even better: Let me know how to figure out which settings to use for which games ?
    Skull
    27.09.2005
    822
    a-ray is way old too, version reported is very wrong...
  5. #5
    Quote Originally Posted by evlncrn8 View Post
    Ok - What should I use instead ?
    And what about Rainbow Six Vegas ?
    Skull
  6. #6
    Use ProtectionID.
    Use the same settings for Vegas.
    Use ProtectionID.
    I tried that - Unfortunately with no luck. Is there a 'magic' sequence in which I have to start DT, mount the image and start YASU (or something else)?
    Skull
  8. #8
    You get the same error, dont you?
    Also you have to use latest YASU (yasu.copybase.ch).
    Yes, I get the same error.
    Downloading the latest YASU didn't change matters :-(
    I have also tried to physicaly disconnect my only DVD-Drive.
    Skull
  10. #10
    "Please insert the original disc instead of a backup." means that your image is bad. Y.A.S.U won't help you in this case. try to recreate the image (extract DPM with high accuracy and at maximum speed). if this doesn't work your DVD drive is probably unable to extract a good DPM (don't ask me why the other disc worked ).
    did you check the quality of your DPM? use the MDS-Viewer therefore!
