help! my dvds could not be loaded!
    Originally Posted by A.Hecka View Post
    Maybe he just switched autorun/change detection off? Donґt know how these two feature are called in english os-builds... Should be Autorun and...?
    dun rly understand wt u r talkin abt, but anyway, wt should i do to switch between autorun/change detection off?
      BTW: Which OS do you have?
      Maybe only autorun is disabled.
      Copy the following text into a
      textfile and then save this file as
      a .reg file and execute it.
      Windows Registry Editor Version 5.00
      [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdrom]
      "AutoRun"=dword:0000001
      [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
      "allocatecdroms"="0"
      [HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer]
      "NoDriveTypeAutoRun"=dword:00000095
        i am using windows xp service pack 2
        nothing happened after copying the text
        the dvd-rom rotates inside the drive, but i just cant play it
          when i double click on the icon of the drive, it asks me to insert a cd/dvd
            Mybe a stupid question: But
            did you also execute the reg file?
              sure i did
                You should then try
                TweakUI to enable
                the autorun feature.
                  You should then try
                  TweakUI to enable
                  do u mean autoplay
                  i've ticked all but nothin happened.
                  i dun rly thk it's abt autoplay or not. the dvd drive can't even sense i've put a dvd-rom into it!
                    Hm, then the problem
                    might be even worse.
                    Let me think about it...
                      This is truly an odd problem...
                      Lets hope we can sort it out for you...
                      Is your O/S (operating system) on IDE or SCSI/SATA drives?
                      Mail:
                      curerom @ daemon-tools.cc
                        how can i noe that...? i m not too sure
                        there r primary IDE channels and secondary Ide channels... so i thk on IDE?
                          plz help me
                            Ok, try uninstalling Daemon-Tools and/or Alcohol 120%/52%...
                            Then you must also uninstall the SPTD driver, for info on how to do this check here
                            reboot your pc... is your drive still giving problems?
                            Mail:
                              it can't help...
                              would it be my drive's problem!? but it can't work immediately after usin YASU...
                                help=(i can't do anything wifout it
