Page 13 of 13 FirstFirst ... 3111213
Showing results 121 to 129 of 129
Thread: YASU 1.3.7070 released
  1. #121
    Quote Originally Posted by hadjy View Post
    hi, i'm trying to run resident evil 4, i'm using daemon tools 4.10 and YASU but i keep geting this error and can't run the game, can someone help me?
    I have the same problem too. The game will usually start after 3 - 5 attempts playing around with it and Yasu enabled.
    It would be much more convenient for it to start up within the first try, but I guess Yasu hasn't successfully or completely Anti-Blacklisted the version of Securom Resident Evil 4 (PC) uses.
  2. #122
    07.10.2006
    157
    your image is bad.
    A Game doesn't start the 3rd - 5th time because of a Blacklist but most likely because of a bad image.
    Upgrade your programs:
  3. #123
    i thought vIDE isn't needed for blacklistng cause it acts as a real dvd drive
  4. #124
    Default Yasu
    Iv Tried To Dowmload This But Cant Get It To Work New To This Can Antone Help Iv Been Told It Works On The New Theory Test Cheers Terry70
  5. #125
    Yasu wont work fine for alone in the dark, securom for aitd 5 detetcs emulation software though yasu claims to be cloaking all virtual drives any solution ?
  6. #126
    07.10.2006
    157
    Yasu is outdated!
    Try updating to latest SPTD/DT versions and avoid using Yasu.
  7. #127
    Quote Originally Posted by tranquilizer View Post
    This is NOT a YASU Problem! SR7 Blacklist the current Virtual Drives! i can play Aitd, the Abbey.Sunrise... in the Virtual Drive from Alcohol with Y.A.S.U.1.3.7071 fromt he 18th sep. 07.
    believe me! plug out your physical drives and try it! you will see SR7 still detect a conflict with emu soft.!
  8. #128
    11.11.2008
    1
    Default yasu 1.3
    dudes how do i use yasu 1.3? its the first time when i got it and i really dunnot know how can i start my game with it. can someone please help me?
  9. #129
    Just run it and click on Cloak.
