Page 2 of 13 FirstFirst 123412 ... LastLast
Showing results 11 to 20 of 129
Thread: YASU 1.3.7070 released
    08.08.2007
    4
    Quote Originally Posted by sYk0 View Post
    Is there any1 else having troubles with the new version...?
    Unfortunately, i do
    I can see it in taskmanager ,it use 99% of cpu but nothing appear (no interface)
    i hadn't that with the previous versions...
    Any idea on why it does that?
    Thank you sYk0. Everything is working fine. No trouble with C&C 3
    KE 1.6.
    sYk0's Avatar
    27.12.2005
    392
    for any1 who's having trouble...!
    Post your system specs... O/S, CPU... the usuall stuff...
    also include how many real CD-ROM's you have in your system...
    Mail:
    curerom @ daemon-tools.cc
    sYk0's Avatar
    27.12.2005
    392
    Quote Originally Posted by ghost_zero View Post
    I thought it would be v1.4 ..?
    Yes you are correct...
    It was supposed 2 be...
    However... Myself and Benni came 2 a decision that the wait was too long, and decided to release 1.3.
    Mail:
    Reef's Avatar
    30.03.2003
    860
    I found the problem! For some reason, permissions are set to deny after every reboot for this registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Cdrom\Enum
    So YASU can not properly cloak drives. If I manually change change permissions first, run YASU and cloak, the game runs fine.
    Now all I need to know is what changes these permissions every time, so I can disable it. Does anyone have any idea how I could do that?
    Edit: it should be Services, not Servic es (this is a bug in vBulletin).
    08.08.2007
    4
    Well don't know if the previous message is already approuved but following to my previous message,
    I'm under Windows XP sp2
    Spec:
    Athlon xp 2800 barton
    1hd sata +1 ide 133
    1Dvd writer
    hello. I have exactly the same problem as Krzmnd, nothing happens when i try to start yasu 1.3.7070 but task manager shows yasu using 99% of cpu. my system is:
    -windows xp sp2
    -athlon 2600+ barton
    -512 ram
    -one 250Gb SATA hard disk
    -1 dvd-ram drive and 1 regular dvd drive
    - also i recently upgraded to daemon pro and uninstalled alcohol
  8. #18
    Same problem as Krzmnd here, 99% CPU usage but no interface.
    XP Pro (32bit)
    Athlon XP 2800+ (2GHz)
    1 x IDE DVD/RW
  9. #19
    Reef's Avatar
    30.03.2003
    860
    My system specs:
    AMD XP 2400+
    1 DVD burner NEC 3520A
    1 CD burner Lite-On 52x
    Running XP Home SP2 32 bit.
    It seems like it is Windows changing the registry permissions, cause I tried booting with all startup programs and services disabled, and the permissions were still reset to deny.
  10. #20
    07.10.2006
    157
    i have the same problem as Krzmnd.
    YASU takes 100% cpu load.
    I have 2 optical drives at the secondary IDE Channel.
    XP Ahtlon 3000+
    1GB RAM
    2 HDDs (one not working probably at the moment)
    Windows XP Pro SP2
    Upgrade your programs:
