YASU 1.3.7070 released
  • #46
    Test Drive Unlimited with patch still dosent work with new yasu, deamon tools still gets detected.
    • #47
      100% CPU using too.
      AMD Athlon 64 3200+.
      waiting for a fix.
      • #48
        I tested YASU V1.3 with Test Drive Unlimited 1.66a and it works perfect. Mayby your image is bad, or you have other programs installed wich are blacklisted.
        • #49
          Maybe it is some SecuROM bug... Have you tested your original already? If that one doesn't work too, you should contact SecuROM support...
          MrFrost is not the only one that confirms that it is working, therefore I guess it is some specific problem you have...
          Have you tried renaming your DT-Drive? I mean changing Model and Vendor and maybe also drive letter?
          I had often a SecuROM problem regarding this already...
          It either took far longer to verify (it always takes longer the first time - because it has to find out the correct parameters - but after that it should be verified in a couple of seconds) or didn't work at all if this happened (which is a result of wrong parameters for verification)...
          Also: What error message do you get exactly?
          • #50
            Could also be the same problem I had, permissions set to deny on this registry key:
            Code:
            HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Cdrom\Enum
            YASU can't cloak drives properly when access to this key is denied.
            • #51
              Originally Posted by Benni View Post
              [*]Fixed Lame SecuROM 7.330012 Blacklist of Y.A.S.U.
              "Lame" is the official Copyprotection name ??
              • #52
                CPU Type AMD Athlon XP, 2200 MHz (11 x 200) 3200+ (Barton 2500+)
                Motherboard Name Gigabyte GA-7N400 (5 PCI, 1 AGP, 4 DDR DIMM, Audio)
                Motherboard Chipset nVIDIA nForce2 Ultra 400
                System Memory 768 MB (PC3200 DDR SDRAM)
                Disk Drive JetFlash TS1GJF2A/120 USB Device (996 MB, USB) (flash drive)
                Disk Drive ST380011A (80 GB, 7200 RPM, Ultra-ATA/100)
                Disk Drive WDC WD1200JB-00DUA3 (111 GB, IDE)
                Optical Drive _NEC DVD_RW ND-3540A (DVD+R9:8x, DVD-R9:4x, DVD+RW:16x/8x, DVD-RW:16x/6x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW)
                Optical Drive FF1409L JFD891Y SCSI CdRom Device (daemon)
                I have the same problem (99% cpu usage and no interface)
                • #53
                  Originally Posted by Prataten View Post
                  (i have plenty of spare parts flying around)
                  What, you mean like Poltergeist style? I'd be getting out of there if I was you...
                  On a serious note, it appears to work OK on both of my AMD systems, too. I doubt it has anything to do with AMD. I think that's more coincidence than anything.
                  • #54
                    It is the same on me:
                    100 percent cpu using.
                    If i see all the post's before is it a amd prob, isn't it?
                    • #55
                      Same here. Here are my system specs.
                      AMD Athlon64 3000+
                      LITE-ON 811S DVD+RW Drive
                      Windows XP Pro SP2 x86
                      Daemon Tools 4.09.1 / SPTD 1.5 x86
                      • #56
                        Also nothing but only 100% CPU load when starting YASU 1.3 on my Sytem (AMD ATHLON 2500+ , WinXP SP2)
                        • #57
                          DL link not working for any one else?!
                          • #58
                            Sorry, our provider has a problem with its power supply at the moment.
                            MfG, Benni
                            Mail: benni@copybase.org
                            • #59
                              same problem here
                              100% cpu usage
                              ADM athlon 3200+
                              ASROCK dual S-ATA
                              2Gb dual channel
                              8800 gts nvidia
                              2 hd IDE
                              1 SATA
                              • #60
                                AMD64 4000+ (3.1ghz)
                                MSI Neo2 Plat
                                WindowsXP Pro SP2
                                Works fine here. None of this "100% cpu usage".
