Page 2 of 2 FirstFirst 12
Showing results 11 to 18 of 18
Thread: Bioshock
    20.08.2005
    654
    What drive do you use?
    Schreibt mir eine PN!
    14.10.2004
    7
    Its liteon CDrom
    I have no problem making images with Alcohol 120%. I already summit my log up. hope to know what is the cause
    and I hate SecuROM blacklisting the new version of DT Pro
    Thorandor's Avatar
    03.11.2005
    123
    To be fair, I would invest in a new drive if I were you, nycgps. I have had a liteon drive in the past and I wasn't really happy with it (that is not to say that LiteOn is a bad manufacturer, nor do I want to stir any emotions about that, its just personal experience). The two manufacturers I would go for are LG and NEC, never had a problem making a backup with them.
    nycgps, you said you had no problems with Alcohol making an image, did your Bioshock image work using YASU at all? Or did it throw an error there, too?
    If the minimum wasn't acceptable it wouldn't be called the minimum.
    Quote Originally Posted by umbrella View Post
    At that moment just rename folder where game is installing. When setup is closed rename it back.
    So I am alittle confused by Umbrella's comment about renaming. So do I rename after the install when I see Bioshock trying to download the update? If so, one must be very quick to do this, the download screen pops up and then it checks for the original disc, which is already inserted but for some reason doesn't like DT running. Or does Umbrella mean to choose a different directory to install to from the start?
    Thanks
    I have the same issue with World in Conflict, C&C, and Crysis. Man did I make a mistake buying this and not the Alcohol 120%? Sure seem like people are having a better time with that application then speading hours of time wasted trying to get DT Pro to work.
    These games are working fine with latest DT Pro Advanced.
    Which "same" issue do you get exactly?
    Im also having the same problem with Bioshock, mounting the image with DAEMON tools lite and it installs but begins searching for the newest patch and then the notice comes up telling me to put the original disc in and not a backup...i am also confused at what umbrella is saying to do
  8. #18
    Bad image - recreate it with New SecuROM profile.
