Showing results 11 to 20 of 28
Thread: "Add IDE Virtual Drive" is grayed out
    You go to the same location as you downloaded DT Pro 4.10.0218 and say "revoke" and then you can upgrade to latest version.
    Unglücklich Greyed out ide.
    I too have the problem where it is greyed out. Start Ide adapter is greyed out in virtual device manager. I've just bought the latest version of daemon tools pro advanced 4.12.0220 sptd version 1.55 about 1 hour ago and i'm running windows x64. I'm not using alcohol or anything similar. Any suggestions or is this due to windows x64?
    My first post, go easy.........
    Jon
    Customer Terramex's Avatar
    06.09.2004
    2,566
    @Pirate69
    Sorry to say so, but
    vIDE is currently supported on all 32 bit platforms (x86) and on Windows Vista x64; Windows XP x64 and Windows 2003 x64 are not supported
    http://www.disc-soft.com/faq#faq01
    10.04.2008
    1
    it is supported, but mine is both grayed out like pirate69's
    Same problem can't active IDE virtual drive. "error Unable to add the adapter device problem 1" or "error Unable to add the adapter device problem 28"
    Daemon-Tools Pro Advanced 4.12.0220
    window XP SP2 32bit
    On the windows hardware wizard it also says " Error occurred Driver is not intended for this plataform" Guess it might be because i have no pata drives in my pc only sata.
    Also the updating service is quite anoying how can i make the Daemon-Tools client detect that i have web? any other easy way to update?
    Update to Daemon Tools Pro Advanced 4.12.0223.
    I am running Daemon Tools Pro Standard version 4.35 and I have the IDE greyed out. I opened virtual device manager but it only shows SCSI drives and nothing about IDE. I unloaded Daemon tools and reloaded again from their website but still no luck..Any advice please?
  8. #18
    Install Advanced version.
    Default IDE Greyed out
    Quote Originally Posted by Copytrooper View Post
    Did you start virtual IDE controller in Virtual Device manager? It is not running by default.
    When I open Virtual Device Manager ther is NO virtual IDE controller...only virtual SCSI controller...and I also cannot load bin files even though I have them marked on....I am also running the version 4.35 and with Windows XP Pro SP3
  10. #20
    but I the license for the standard version NOT for the advanced.
