The team has the programm code and could see whether it's bug in the language file or in the programm itself.
So just send them the dll.
Schreibt mir eine PN!
realx3m, please, check your Private Messages.
DAEMON Tools Pro Support Team
DAEMON Tools online help systems: http://daemon-help.com
http://daemonpro-help.com
@bismax I figured that out,i just didnt know where to send it.Thanks for your effort regarding my problem.
I also have same problem with DT Pro Agent. All translated strings are displayed blank. Should I send my translation too? (CP1250, Langcode 1045)
Edit:
Seems that compiled DLL file contains strings with LANG_ARABIC instead of LANG_POLISH (checked with ResHacker). Could be the cause?
Hi. Yes, please, send ua the file.
And one more question. Did you use TranslatorTool or any other software to translate the strings?
It is strongly recommended to use TranslateTool.
I did use Translator Tool to make translation. ResHacker was used just to snoop arround
Where shall I send this translation?
Just zip your file, make a post in this thread like other guys did before:
http://www.daemon-tools.cc/dtcc/list...ol-t18740.html
I got the same problem... i am trying to figure out what it is.. will send my translation when it is totally finished! (and it is almost done)
btw: i used the translater and i used the files which came with it.
sorry cant edit post above..
after saving 4313 it deletes the make up of the text for this one (my translation side but also the English side) can somebody test that, or is it just me?
Well everything works fine here. Did you use the right languageID?
