o i am so stupidit works now!! thank you.. i had a space behind it, think that caused the error...
Shit happens :P No problem. We have enough time.
Schreibt mir eine PN!
I agreeWe all do simple mistakes.
Problem solved.Thanks to everyone for the effort.
I hope that the issue will be addressed in the next version of DT
so it wouldnt be done manualy.
I am translating in Romanian and I have the same problem with the Agent - blank lines, like the screenshot in the first post.
Thanks,
OJi.
edit 1 - sorry, I missed the posts above...
edit 2 - after changing the ID from 1048 to 00000018, I have text in the Agent.
The correct hexadecimal number for 1048 should be 418 (enter 00000418 as language ID in DTPro Translator). Maybe it was just a typo?
Anyhow, it would actually probably work if you used ID 18 - because it isn't in use by any other language file in your installation, and DTPro doesn't seem to verify the ID. But it wouldn't be the correct identification of your language![]()
I Googled for 'language id' and I found this http://helpnet.installshield.com/rob...dentifiers.htm. I compared with the ID you told 'chrashoverraid' to use for Dutch - 0413, it was a match. On that page I found 018 for Romania, so I used it. My mistake.
If the right ID is '00000418' I will use that.
Thank you,
OJi.
I just read through the page you're mentioning, and it really puzzles me. Because in many cases, they use the hexadecimal value for the standard language code, but other times they don't (for example for Romanian, Danish etc.).
I can promise you that the Romanian language code in hecadecimal is (00000)418. But I don't understand why InstallShield InstallScript uses something else.
However, I read the following on the page you mentioned:
So, apparently, InstallShield uses (in some cases) some non-standard language IDs.The language ID is more commonly given as a hexadecimal value, but you must specify the decimal version for Windows Installer. Note that Windows Installer based installations (including InstallScript MSI installations) use different IDs than InstallScript installations.
Check out this page:
http://www.science.co.il/Language/Lo...?s=hexadecimal
Hello everybody
Just small note about language ID
http://www.microsoft.com/globaldev/r...p/langtla.mspx
It's simple, paste language ID from the table with leading four zeroes, i.e.:
Portuguese - Brazil lang ID = 0416
so, paste 00000416
