Page 1 of 3 123 LastLast
Showing results 1 to 10 of 26
Thread: [Freeware] Program for textcapture
    26.06.2007
    115
    Frage [Freeware] Program for textcapture
    I am looking for a free program
    which is able to capture non-editable
    text and to copy it as editable text
    into the clipboard.
    Under non-editable text I mean
    text like in the following window:
    27.09.2005
    822
    winspy at worst will do the trick
    26.06.2007
    115
    That should really be the worst
    solution.
    The program should also be able to
    capture the text inside a region.
    Customer
    Terramex's Avatar
    06.09.2004
    2,566
    Sorry, no freeware, but if 21 days are enough for your needs, try Grab Text
  5. #5
    27.09.2005
    822
    Cool
    maybe pid will have a plugin for it
  6. #6
    26.06.2007
    115
    @Terramax:
    Thanks. This program as freeware would
    be perfect.
    There must be something, can't image
    I am the only one who wants this feature.
    @evlncrn8:
    You mean ProtectionID?
    Why should it?
  7. #7
    27.09.2005
    822
    yep, protectionid.. why? ...cos its got lots of plugins
  8. #8
    26.06.2007
    115
    And does it have a plugin
    for text capture?
  9. #9
    27.09.2005
    822
    does now ;p
  10. #10
    26.06.2007
    115
    Do you have a link to
    the plugin?
