Problem with newest YASU and Daemon Tools and Securom
    WOrkED FOR ME TO!!!!!
    Thanx alot Mury!!!
      I'm also having this same problem, but with Hellgate London. Multiplayer works fine, but single player will not load. I've tried DT4.06 with no change. When I get the 'emulation software detected' box, there is no link to click for further information.
        same problem here with hellgeate london. i didn't try 4.06 because i need the vide for the witcher :-(.
        so we have to play with dvd and wait...
        seems that securom blacklists the software somehow instead of the drives - yasu is cloaking.
        starforce used in dirt 1.2 works in a similar way?!
          same problem here
            me too having the same problem with Hellgate London(using DT 4.10.0218 with YASU 1.4 build 7080). Hopefully the new ver. could solve this problem
            Btw, what kind of image type you guys normally create from the protected dvd games?...Thanks.
              Have you tried with SPTD 1.51 beta?
              Carpe diem
                Thanks Mury, I went back to 4.06 and it works now!
                  There is no problem installing DT Pro along with DT Lite.
                  btw. You should contact an official to get your customer tag.
                    Yes, it still won't work for me. I've tried everything but I always get the error that the emulating software is detected. Does it work for you with 1.51 beta?
                      Don't know for Hellgate, don't have and I won't get it.
                      Timeshift 1.1 runs well with it, on a side note.
                      On another side, I didn't test it on my XP comp (and I won't coz it cannot even run neverwinter )
                      Carpe diem
                        Timeshift 1.2 does not run well with this!
                          How to make Hellgate London work
                          I did it!!!
                          for it to work u need daemon tools 4.6, latest y.a.s.u, SPTD 1.51 beta.
                          The trick is that in order for y.a.s.u to work properly on hellgate u need to open up your device manager and disable all your cd/dvd
                          and also all your IDE controllers.
                          After u have done that just mount on daemon, use y.a.s.u and enjoy the game .
                            Timeshift 1.02
                            Hi,
                            I am experiencing pretty much the same problem with TimeShift 1.02 patch, which I assume introduced an improved copy protection. (PID says "securom 7.xx")
                            What has changed in daemon-tools 4.06 to 4.10? Could we get whatever securom's detecting to be reversed? If it can be fixed with a hex-edit on the daemon tools exe, let me know what the offset and the string is :-D
                            Someone should report this to the daemon-tools copy protections page, as it seems to not be a YASU issue, but a DT one.
                            Thanks
                              Experiencing same problem with Crysis.
                              Installed LATEST Yasu, Cloaked everything, but still wont work.
                              (Thread below)
                              if you want me to remove link, just say so
                              One sheep - Many Sheepah.
