ERROR 25009
  • ERROR 25009
    Operating System: Windows XP Professional - Dutch SP1 FULLY UPDATED
    Burning Software: NERO Express 6.3.0.0 [OEM Suite]
    Anti-virus Software: Norton AntiVirus 2004
    DAEMON Tools Version: had 3.41 wanted to install 3.43
    i have the same problem as discribed in: http://www.daemon-tools.cc/portal/viewtopic.php?p=7862
    I also have the problem the first time i wanted to re-/uninstall it.
    then i try it again.... it uses 99% CPU utilization on process Services.exe and then i had to use the :!: reset button :cry:
    Tried it a couple of times and gave up...
    Can you help me? It WON'T uninstall properly. @ 99% of the uninstall it hangs and 99% CPU Utilization comes up. When i click close it asks me to stop but 'ignores' my YES
    Look @ the lower part of daemon.log:
    Code:
    Action 19:23:12: RemoveFiles. Removing files
    RemoveFiles: File: 1033.chm, Directory: C:\Program Files\D-Tools\Help\
    RemoveFiles: File: tray1.ico, Directory: C:\Program Files\D-Tools\Icons\
    RemoveFiles: File: st3shark.sys, Directory: C:\WINDOWS\SYSTEM32\Drivers\
    RemoveFiles: File: pnpshark.sys, Directory: C:\WINDOWS\SYSTEM32\Drivers\
    RemoveFiles: File: pfctoc.dll, Directory: C:\Program Files\D-Tools\
    RemoveFiles: File: tray2.ico, Directory: C:\Program Files\D-Tools\Icons\
    RemoveFiles: File: daemon.dll, Directory: C:\WINDOWS\
    RemoveFiles: File: mdsmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\
    RemoveFiles: File: ccdmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\
    RemoveFiles: File: 1033.dll, Directory: C:\Program Files\D-Tools\Lang\
    RemoveFiles: File: nrgmount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\
    RemoveFiles: File: daemon.exe, Directory: C:\Program Files\D-Tools\
    RemoveFiles: File: pdimount.dll, Directory: C:\Program Files\D-Tools\Plugins\Images\
    Action 19:23:12: InstallFiles. Copying new files
    Action 19:23:12: DaemonDriverUninstall1.
    Action 19:23:26: Cancel. Dialog created
    Action 19:24:01: Cancel. Dialog created
    I might know what the problem is. There are devices in Device manager called:
    • PnP BIOS Extention <<< Has an :!: ERROR CODE 19
    • Plug and Play BIOS Extention < Says it's OK
    Code 19 says:
    Windoze could not start this device because the config information in the register is damaged or missing
    When i try to remove one of those it gives me the 99% CPU usage again on process Services.exe
    Do you use the PnP BIOS Extention driver?
    Ill try b!tch!ng the driver up and hope it can be removed and installed correctly.
    Wish me luck, or help me finding a solution
    P.S. Merry Christmas people!
      I also tried disabling > remove after reboot... Didn't work.
      Well... my system is f*ck'd up now so ill reinstall it because i used the reset btn too much.
