workd in conflict patch 1.001
    That error means your image is bad.
    Recreate it with New SecuRom profile in DAEMON Tools Pro, Alcohol 52% or Alcohol 120%. If you then get the message again, try to lower your DPM reading speed.
      Hey:
      Thanks, I'll look into buying the DT pro license and do that, only, could you elaborate a little bit on that DPM speed settings?
      Many thanks for your help
        Lowest DPM speed is the best.
          Just to add to Blazkowicz's post, many times DPM is best at maximum for DVD media. Try maximum, and if it doesn't work, then try throttling the speed down.
            Cool:
            Thank you all for your help I will do tests in this week and let you know what happends, I just bought MAss Effect too, any issues know to this game?
