Page 5 of 6 FirstFirst ... 3456 LastLast
Showing results 41 to 50 of 55
Thread: Crysis Protection Type?
  1. #41
    thanks guys, but i figured it out last night, working crysis mini, ranging 10mbs or so, typed up a tutorial for another forum, will post it here as well
    i am SuppA-SnipA
  2. #42
    Default Crysis 1.2
    Just installed the patch and Crysis would boot. Conflict with emulation software message. Newest DT and YASU 1.4. SecuROM 7.36.0007 with Protection ID 6.
    Edit by Underheaven : post moved to correct thead
  3. #43
    Customer Terramex's Avatar
    06.09.2004
    2,566
    http://www.crymod.com/thread.php?threadid=15318&page=1
    6. "Conflict with Emulation Software Detected"
    * Open the Game DVD in your drive (DVD) or go to the directory where your installation is located (EA Download Manager).
    * Open the Binari~1.cab (Bin32) or Binari~2.cab (Bin64) with WinRar or a similar pack-program and copy the Crysis.exe file.
    * Place it into your installation directory of Crysis\Bin32 or Crysis\Bin64 and replace the existing .exe file.
  4. #44
    21.10.2006
    26
    any ETA on yasu update for blacklist of crysis 1.2?
    Regard Solway
  5. #45
    06.09.2004
    2,566
    @solway
    It's more likely this will be fixed with a new DT Pro/lite version.
    A workaround for Patch 1.2 can be found above your post
  6. #46
    21.10.2006
    26
    replacing exe with original from dvd, does'nt that mean 1.2 updates won't work?
    There was another thread (deleted now) which mentioned about enum reg hack? what is it?
    FYI
    PATCH 1.0 EXE
    Scanning -> \crysis.exe
    File Type : Exe, Size : 4674784 (04754E0h) Byte(s)
    -> File Appears to be Digitally Signed @ Offset 0474000h, size : 014E0h / 05344 byte(s)
    -> Suspicious MZ Header..
    [!] SecuROM Detected - Version 07.34.0014
    - Scan Took : 1.922 Seconds
    PATCH 1.2 EXE
    Scanning -> \Crysis.exe
    File Type : Exe, Size : 5018848 (04C94E0h) Byte(s)
    -> File Appears to be Digitally Signed @ Offset 04C8000h, size : 014E0h / 05344 byte(s)
    [!] SecuROM Detected - Version 07.36.0007
    - Scan Took : 1.953 Seconds
    Regard Solway
  7. #47
    06.09.2004
    2,566
    @solway
    As long as you see 1.1.6115 in ingame menu everything should be fine.
  8. #48
    Default ...
    Quote Originally Posted by solway View Post
    Send a PM to Niko76, he is the one that invented or wrote about the idea .. and didn't want to write it for SecuROM to see.
  9. #49
    I'm having trouble getting Crysis to load correctly.
    I have DT 4.06, and Yasu 1.4 yet i always get the error, "Conflict with emulation software"
    Has anyone else been able to figure out what the issue is?
  10. #50
    Also, whenever i run yasu i get the error, "Unable to located the file "daemon.dll" and/or "dtpro.dll".
    Yasu is in my daemon tools directory and works perfectly fine with Frontlines Fuel of War, but whenever i launch Crysis for some reason it cant find daemon tools correctly.
    Note by Underheaven : the forum is moderated for users with under 20 posts. We try to approve the posts as soon as possible.
