Page 2 of 2 FirstFirst 12
Showing results 11 to 19 of 19
Thread: Translation related bugs in DT Pro 4.11.0219.0
    18.12.2006
    42
    Just found a wrong tooltip on 'Use proxy server'. It uses the one for automatic startup.
    Experienced User OFFICIAL TRANSLATOR
    mastermind's Avatar
    30.11.2005
    274
    Quote Originally Posted by Timmnuv View Post
    Already reported
    Please post all english strings here and where you can see it in program, so developers only have to look into this topic.
    Click on the arrow next to Switch All and you will see "Add or Remove Buttons". Clicking on this you will see "Customize..." Clicking on this you will nearly see only English strings except the right column of Commands. Also when clicking there on New, Rename and Delete everything is still in English (also the warning at Delete).
    Image catalog, select an image and select mount. Captions and buttons are still in English. When creating a new folder it is called "New folder".
    Event manager, the events are still displayed in English.
    Add images, you will see "All supported images" and "All Files". It works with agent, but not in GUI.
    At recent used image if the image isn't found it will display "Invalid link".
    At image details and image creation it will display "bytes" and "sectors"
    Do a right click on caption at the top and it is still in English.
    Do an update check and it's still in English.
    Removing dtpro.key will cause an error message in English. Activation screen is also in English.
    Click on help, about and "This software ...".
    So far that's all i found and isn't already reported in this thread.
    When doing update check and server is not available it will give you the error "Connection to server failed.
    Please check your internet connection and any firewall software you may have." Clicking on Connection settings... will also display English strings.
    BTW disc-soft is currently down
    When adding multiple virtual drives and then doing ALT+TAB you will see the following as caption of DT Pro:
    Operation in progress...
    And in help/about you will see "About Daemon Tools Pro" as caption (you can also see with ALT+TAB)
    At image creation you will still see "Cancel" and the message after pressing "Cancel" is in English.
    If some application still access the drive which has an image mounted and you stop this adapter you will get an mix of translated and english strings.
    It would be good if you would just say the drive letter instead full path.
    Little error again.
    If you get the message "File corrupted" the caption is still in English (Error) and not in translated language.
    DT Pro software validation warning message and when it's expired are not in translated language, still in English.
    Using agent, mount image and most is complete in English (open etc.). Is it possible to read these strings from dll instead of windows?
