Showing results 11 to 20 of 25
Thread: Pls update your Translations for DT 4.11 !
    Experienced User OFFICIAL TRANSLATOR
    mastermind's Avatar
    30.11.2005
    274
    Quote Originally Posted by jdaniel View Post
    it would be nice to have a changelog for the DLL. What is changed, new strings no. 12345-13456 etc
    Strings that are already translated shouldn't be necessary to update (in connection with new updates). I don't agree that it would be appropriate or necessary to have a changelog when a new language file comes out. The only thing you have to do is to translate the empty strings, and there's normally not more than 10-15 strings with each new update.
    jdaniel's Avatar
    09.09.2007
    58
    Quote Originally Posted by mastermind View Post
    I totally agree with this. I was referring when and if strings are changed, corrected, replaced etc.
    Thanks,
    OJi.
    UKRAINIAN TRANSLATOR OFFICIAL TRANSLATOR
    oder2's Avatar
    29.09.2005
    368
    If you have a Visual Studio or any other resource editor capable of handling unicode message tables you can copy messagetable resource from DLL into a .RC file and compare for changes with any text comparer tool.
    mastermind's Avatar
    30.11.2005
    274
    Thanks,
    OJi.
    Yes, if existing strings change mentionably (i.e. the meaning/message of the string changes), I agree with you. We would obviously need to be notified of a change that would need our attention. But that said, I neither think nor hope that it will happen. Existing strings should always keep their meaning, and if a string gets obsoleted, it should simply be removed and the string ID not to be re-used.
    jdaniel's Avatar
    09.09.2007
    58
    Thanks for repying. Again I agree with you.
    OJi.
    oder2's Avatar
    29.09.2005
    368
    Strings that are already translated shouldn't be necessary to update.
    I must disappoint you. The existing strings are changed from time to time in new releases. You just may not know about it.
    I watch for it every time comparing old and new DLLs the way I described earlier in this thread.
  8. #18
    mastermind's Avatar
    30.11.2005
    274
    Quote Originally Posted by oder2 View Post
    I'm in no doubt that the strings are updated; small grammatical corrections and such. But I have a hard time believing that they change meaning, in other words that the purpose or message is changed. I have done comparisons myself in the past, without seeing any significant changes to existing strings. If you insist that there has been significant changes to existing strings, please give examples so that I can check my translation.
  9. #19
    jdaniel's Avatar
    09.09.2007
    58
    Yes ! Many thanks ! This is how it should be.
    OJi.
  10. #20
    oder2's Avatar
    29.09.2005
    368
    The meaning changes are not significant, but if you want stay close to original string you need to change your translation as sometimes wording is changed significantly.
