Page 7 of 9 FirstFirst ... 56789 LastLast
Showing results 61 to 70 of 84
Thread: ProtectionId Info thread - Current 6.3.5
  1. #61
    27.09.2005
    822
    got the files, the patch is to allow you to run any themes (without the patch you can only use signed ones).. correct?, if so, does the problem happen if you use another theme (and this patched uxtheme.dll file) ?.. if not, then the problem is in the theme itself.. if so then the patch in the dll isn't a good one
  2. #62
    It seems not work for other theme either.
  3. #63
    27.09.2005
    822
    and if you use one of the microsoft themes?
  4. #64
    Even with the default Windows XP theme.I found the problem exists.
  5. #65
    27.09.2005
    822
    hi, might have a new beta for you to check to see if the problem disappears (i think it might), i don't appears to be able to send you a private message on the board here, so it could be a bit tricky sending you a link for the next beta, but we intend to release another version in about 1-2 days
  6. #66
    Reef's Avatar
    30.03.2003
    860
    I think he needs 20 posts to be able to use the PM system. He's got 19 right now, so one more and he's good to go
  7. #67
    OTL,
    That is really a problem.
    So after this post,I can use PM.
    Hope for new version.
  8. #68
    The new beta works.
    Snapshots have been sent to you by PM.
    Thanks for your work.
  9. #69
    27.09.2005
    822
    no problems, happy to help that bit of the code needed rewritten anyway, you just 'pushed' me to do it
  10. #70
    Hehe,Both of us are winner.
