Page 2 of 7 FirstFirst 1234 ... LastLast
Showing results 11 to 20 of 68
Thread: How to make Crysis mini image
    Quote Originally Posted by hugeimg View Post
    hmmm, do u have only 2 languages in ur Special Edition (presume from the size of ur MDF)
    as far as i know, only english
    dcadler: try a lower dpm speed, but leave precision at high
    i am SuppA-SnipA
    your drive quality can matter too, so take that into consideration, and if your ripping from a burnt copy, i dont believe that will work
    i am SuppA-SnipA
    i can not edit, so i must tell everyone, use the latest Alcohol 120% version 1.9.7.6022, people may be using older versions, that could cause problems, update and try again
    i am SuppA-SnipA
    I keep getting an error: "Cannot get the right DPM info from the disk with current device" I tried different speeds, from maximum (which set it at like 49.5x or something) to 4x, but I keep getting the error. Any ideas?
    Quote Originally Posted by voodoo89 View Post
    your drive may not be able to handle it DPM's?
    try at 24 X and leave precision at high, if not, give it a shot with normal, like i've said, this may vary with drive build quality, is it a legit disc? as i also have no idea what errors you would get with a copied disc, nor do i want to know (this is for legit purposes, and im not bashing you or anything)
    i am SuppA-SnipA
    Customer Terramex's Avatar
    06.09.2004
    2,566
    @SuppA-SnipA
    Normal precision isn't enough for Securom.
    @voodoo89
    Depending on your language version one of the attached MDS files might work for you.
    If not then please upload your original "DPM-less" MDS file.
    I will inject the DPM information of another version into your file as all versions mostly share the same data positions.
    Attached Files Attached Files
    @SuppA-SnipA
    @voodoo89
    just giving suggestions
    could be his drive not being up for the job...
    but this tutorial is meant for all versions of the game
    i am SuppA-SnipA
  8. #18
    06.09.2004
    2,566
    Quote Originally Posted by SuppA-SnipA View Post
    So do i :wink:
  9. #19
    Thanks for the tutorial SuppA-SnipA, worked perfectly
  10. #20
    So do i :wink:
    awesome
    Pyr0- my pleasure
    watch out for me when Crysis 2 hits the shelves
    i am SuppA-SnipA
