i have tried it on my other pc, no dice, or maybe i was too tired, still got some testing to do![]()
i am SuppA-SnipA
umm i tried this but i get the "conflict with emulation software detected" warning. This wouldn't have anything to do with the 1.2 patch ??
Yes, Crysis v1.2 blacklisted DT!
Please use the forum search next time!
Schreibt mir eine PN!
Too bad I tried all this after installing patch 1.2...
Apparently the patch also blacklists Alcohol 52/120.
The real trouble is that I don't have a clue whether my mds would work now since I get the "conflict with emulation software" message...
I don't feel like uninstalling and reinstalling Crysis to get rid of the 1.2 update, albeit it would be not big loss... 1.2 didn't solve that heinous sound issue with the game).
@Berserker79
Have a look at this thread
I'm running the following and still get the message, "Conflict with emulation Software" across multiple machines.
DT 4.06HE
SPTD 1.29
Yasu 1.4.7080
Mini Image - NS-Crysis_SR-poseden
Crysis 1.2
I can verify that using the same software Frontlines Fuel of War and BF2 both work.
Hi, SuppA-SnipA is it possible that you please share your .mds file with me, the one that worked with the original Crysis DVD ? I haven't updated my Crysis at all, and all my efforts to create a perfect image from my legit Crysis disk fails!
Thanks to Terramex' advice I've been able to test my mds/mdf image with Crysis. It works fine and can start the game correctly without having the original DVD in the drive.
I've also been able to create the mini-image, so I can run the game without using the original disk (that special edition was to damn expensive I'd be shaken if something should happen to the original disk...) and without losing so much space on my hd!
Thanks for your help guys!![]()
