Page 31 of 39 FirstFirst ... 212930313233 ... LastLast
Showing results 301 to 310 of 389
Thread: Changelogs for ENU.dll
  1. #301
    BOSNIAN TRANSLATOR OFFICIAL TRANSLATOR
    kenan3008's Avatar
    08.12.2008
    10
    There is an error in phrase 4283.
    It says:"...If you have inactived instances slots in your license you can just reactivete using one..."
  2. #302
    Yes, thank you, it is already known along with some other grammer/typos and should be fixed soon.
    SLOVENIAN TRANSLATOR OFFICIAL TRANSLATOR
    24.08.2007
    8
    4235 License validation is failed. After some time you will not be able to use %s.
    Should be "License validation has failed."
    4238 Please connect to the Internet or contact us for technical support if you do have Internet connection on your computer and you still see this message.
    Should be "Please connect to the Internet or contact us for technical support if you do have an internet connection on your computer and you still see this message."
  4. #304
    Thank you, should be changed soon
    EDIT: @oder2
    QA is checking this, so they will do the right thing.
    UKRAINIAN TRANSLATOR OFFICIAL TRANSLATOR
    oder2's Avatar
    29.09.2005
    368
    Quote Originally Posted by ShEsHy View Post
    I would suggest to refrain from such corrections if you are not a native English speaker. As to my opinion, the necessity of "an" before "Internet" is quite questionable. Internet is not a countable item. It is not an object at all.
    There are lots of mistakes in English strings but let yourself make sure your translation does not have those. And English will be ironed out by English speakers.
  6. #306
    jdaniel's Avatar
    09.09.2007
    58
    A few details for this please ?
    5431 Converted Name
  7. #307
    Master
    Sway's Avatar
    09.07.2009
    1,966
    It is converted name of a file/folder. It should be converted to 8+3 format when you use ISO9660 file system.
  8. #308
    24.08.2007
    8
    Quote Originally Posted by oder2 View Post
    Thanks for your concern, but I'm actually better at English than my native language (don't ask me why, wouldn't know the answer to that).
    You are correct, "an" isn't normally needed before "internet", but the string in question is in regards to a "connection", so there has to be an "an" before the "internet connection" (ie. there is no need for "a" or "an" in "I surf the internet", but there is in "I have established an internet connection").
    Native English speakers are not always better at grammar and/or pronounciation than non-native ones. In fact, non-native English speakers tend to focus more while putting together a sentence to make sure it's correctly formed than native English speakers (at least the ones that want their sentence to be understood).
  9. #309
    jdaniel's Avatar
    09.09.2007
    58
    A few details please for Daemon-Search.com translation this time
    61 Location of words
    64 Page modified
  10. #310
    oder2's Avatar
    29.09.2005
    368
    You are wrong because the program requires not a particular Internet connection or several of them but rather an availability of connection in general, as a phenomenon. And that meaning should not be prepended with "an".
