Sims 2 FreeTime DTLite & YASU
    Oops, forgot to add that I tried it without YASU and received the same error message.
      You are either using a mini image or your full image is bad.
        maybe a blacklist?
        i can't play newer versions SR7 Games i.e. The Abbey,AitD 5...
        i disconnect my Pysical drives,use YASU, and disconnect my USB burner. SR7 ask me for the original. The image is ok! RMPS copy work fine... (i use Alc, but this is the same engine (right???))
          I don't know what's the problem with Daemon Tools and the Mini-Maxi images....would you can explain it!?
          or better post a new way to backup a game...because the use of Mini-maxi images is for reducing space in the hard disk...
          also I guess the "Lite" users of Daemon are lost now because their only choice is to buy the Pro Advanced version...
          Thanks in advance...
            Mini/Maxi images issue got resolved in latest DT Lite/Pro version.
              I've tested a mini image with latest daemon tools lite (4.30.1) and nope, the blacklisting is still there...also somebody also made a topic about this...
              I hope the developers find a quick solution for this...
              and better if it will be a definitive solution. :P
              See ya!
                There won't be a definite solution as the copy protection guys aren't stupid.
                You can also use latest DT Pro Advanced
                  A mini image which worked with older versions ?
                  What's the exact wording of the SecuROM error message ?
                  Full image is working ok ?
                    Sorry...I didn't explain very well...I forgot to said that I've updated the game.. (Children of the Nile) to 1.3...which has Securom 7.37, and it blacklist now the use of mini-images...
                    Also my full backup doesn't work...at least the one that I've made years ago..
                    Anyway, the mini-image I've tested was one posted at game****world...
                    I guess this are all the details I can give...see ya!
                      @Bollo
                      As your full image also doesn't work you can't be sure what's blacklisted.
                      If the Mini was working before try its mds file in combination with your full image.
                      The exact SecuROM error message ?
                        Sorry, my mistake, I didn't read that line.
                        Here this messages prompt when I run either of the images:
                        SecuROM
                        And this:
                        SecuROM
                        Thanks for the support...anyway, I'll have the money to buy out the Pro-Advanced version for 5 years...so I hope to don't see this kind of problems...
                        See ya!
                          Bad image - recreate it it with New SecuROM profile and different DPM speeds.
                            ...I've updated the game.. (Children of the Nile) to 1.3...which has Securom 7.37, and it blacklist now the use of mini-images...
                            You live and learn. Got my copy today and this is the first time i've encountered a
                            Securom title that implements an ISO check with a patch.
                            So nothing is wrong with Daemon Tools; it's just some sectors missing in your image.
                            Use a full image instead or leave following sectors in a Mini/Maxi image:
                            Code:
                            1-17
                            233580
                            244183
                            254800
                            265423
                            276038
                            286647
                            297258
                            307871
                            318516
                            329104
                              Yeah Terramex...as you said, "you live and learn"....is there another method, away of making a full-image, where you can select which sectors to preserve in the image....or maybe a way to "insert"(inject) sectors in a image!?
                              Thanks in advance.
                              PD. By the way, how did you realize to know about the ISO checks?...would you can PM me with some instructions in this matters!?
                                Fastest method -particularly for CDs- is using Blindwrite 5/6 as you can specify multiple gaps in custom profiles.
                                Create a new txt-document in BW's profile folder, paste this:
                                Code:
                                [BW5]
                                profilename=Nile
                                profiledesc=
                                default=0
                                visibility=7
                                subfordata=0
                                topologyread=0
                                onreaderror=-1
                                IsoCreationMode=0
                                gap_zone_1=[17..233579]
                                gap_zone_2=[233581..244182]
                                gap_zone_3=[244184..254799]
                                gap_zone_4=[254801..265422]
                                gap_zone_5=[265424..276037]
                                gap_zone_6=[276039..286646]
                                gap_zone_7=[286648..297257]
                                gap_zone_8=[297259..307870]
                                gap_zone_9=[307872..318515]
                                gap_zone_10=[318517..329103]
                                gap_zone_11=[329105..350330]
                                ...and save as Whateveryouwant.ini
                                Open BW, choose the Nile Profile and create image.
                                btw. if your drive is capable to extract topology with Blindwrite you can also set topologyread=1 and just use that image. Otherwise mount the BW image in a virtual drive, and create a new image thereof with DT Pro/Alcohol.
                                DPM has to be done of Original disc of course. I've attached a mds file belonging to an image without subchannel data.
                                Too make your image use less disc space activate Windows compression for the main image file (rightclick on the folder/file and select Properties->Advanced button, then check the box beside "Compress contents to save disc space"); HDD has to be formated in NTFS format to be able to use Windows compression.
                                As this one is a CD read RAW there are still several MB used on HDD.
                                Really small Maxis can only be done with DT Pro Advanced' image converter/compression.
                                Some time ago i wrote a short HowTo.
                                Will send it to you ...when i've found it on my disorganised system
                                Right now i'm too lazy to write a new one; will get in touch with you within the next few days.
                                Till then you maybe want to have a look at a free tool to capture disc activities named TraceSPTI.
                                Depending on Securom version you may have to capture with game executable set to a compatibilitiy mode,
                                otherwise you'll instantly get a Securom security modul error message.
                                First -the predominant part- is the topology check. But we're only interested in the few ISO checks at the end.
                                But let's continue via PM - we're offtopic too long now
