@SnowLeopard
Did you try on Vista too ? Try it if you can.
@SnowLeopard
No, I've avoided Vista as best I can - I have Vista Business licences for my PCs at home, but all have been downgraded to XP Pro.
I have a dual-boot XP/Vista on my laptop, but as I mentioned earlier my laptop has no problems with anything (no RAID/etc).
Sorry
Try 4.10 with SPTD 1.56 and one times with SPTD 1.50.
I have 4.12.4 Lite installed (SPTD 1.56) and am using that for mounting (seems to have no issues) ... Have Pro installed alongside for making images.
It would be nice to have just the pro installed, since I've paid for it and all.![]()
Please post all configuration of your computer etc (in case you already did, sry).
same problem with ver 4.30.3
(dammed my brand new system 4 freezing -.-)
Installed the game later with the cd i deposited at my parents house... .
System:
Intel Core 2 Quad Q9550 2.83GHz 1333MHz S775 12MB 45nm
Netzteil ATX Jersey Black Edition BE-500WS r
GA-EP45T-UD3P P45 S775 1600MHz ATX PCIe512MB Sapphire Radeon HD3870 GDDR4 DVI
2x2048MB Kit OCZ Reaper HPC 1333MHz CL6
1000GB Seagate ST31000333AS Barracuda 7200.1 32MB Sata2
XP SP3
all newest driver etc. installed because i thought i'd be a system problem i reinstall 4.30.0 now![]()
(didn't found the edit
i use AHCI not raid
& it dont work if i downgrad to 4.30.0
even not if i remove the spdt drivers and reinstall
And when you change from AHCI to IDE in SATA options in BIOS?
Ive got this same problem. Ive now tested each of the 4.30.x version and everyone freezes after little while when you copy/install files from mounted image. Currently running 4.12.4 which seems to work without any problems.
Currently running with ACHI mode. Cannot test IDE option since that would require me to reinstall Windows to test(?).
Computer specs:
Code:Computer: Gigabyte Technology Co., Ltd. EP45-DS3P CPU: Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Motherboard: Giga-Byte GA-EP45-DS3P Chipset: Intel P45 (Eaglelake-P) + ICH10R Memory: 4096 MBytes, 5.0-5-5-18 - 2048 MB PC6400 DDR2-SDRAM - Kingston 2G-UDIMM - 2048 MB PC6400 DDR2-SDRAM - Kingston 2G-UDIMM Graphics: Hightech RADEON HD 4870 ATI RADEON HD 4870 (RV770 XT), 512 MB DDR SDRAM Drive: ST3320613AS, 312.6 GB, Serial ATA 3Gb/s Drive: Optiarc DVD RW AD-7203S, DVD+R DL Sound: Intel ICH10 - High Definition Audio Controller [A0] Sound: ATI RV770 - High Definition Audio Controller Network: Realtek RTL8168C(P)/8111C(P) PCI-E Gigabit Ethernet NIC OS: Microsoft Windows XP Professional Build 2600
