I just started seeing this problem too... after switching to Vista (x86 - 32bit). I was using XP (MCE2005). Both the XP and Vista installs had/have DT-Lite v4.30.1 installed, and both are connecting to the same Vista machine that is hosting ISO files (no changes on the ISO server side). The upgrade from XP to Vista was a full reformat/fresh install.
It is strange because if I right click on DT-Lite and choose "Mount Image", I can browse all the way to the network share (let's call it '\\server\ISOs\MyIso.iso'), select the file, and then I get the error... Also, using UltraISO on the same Vista client, I can open the \\server\ISOs\MyIso.iso and browse through the contents of it (extract files, and even burn it to disc).
Perhaps DT-Lite is expecting some form of file lock or sharing mode on the ISO that is not available through shared folders in Vista.
Also, mounting the network share as a drive does NOT fix the problem.
Is this something that would work if I purchased DT-Pro?
